Question about Kitchen Ranges
Lower oven will not work on MGR6775
Upper oven works lower oven does not
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Does the igniter glow?
Posted on Nov 10, 2012
SOURCE: Oven igniters, are both suppose to be on during preheat or bake?
good choice,sounds like the bake igniter is bad
Posted on Nov 29, 2008
heatman101
  • 43501 Answers
SOURCE: upper oven makes loud whooshing noise sometimes ,
The gas is not the problem... the ignitor is...
The gas is building up in there before it ignites because the ignitor is not working properly...
Replace the igniotr and the problem will go away..
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 11, 2010
EllaWatson25
  • 725 Answers
SOURCE: Lower oven does not get hot.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
  • 274 Answers
SOURCE: Gemini Electric Range MER6772BAS- lower oven upper
Replace upper coil by removing,and take it to applance parts dept and have them order a new coil(check coil by using a test meter look for low ohms.
Posted on Jul 26, 2010
heatman101
  • 43501 Answers
SOURCE: lower oven ignitor does not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gsgs
Posted on Sep 30, 2010
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Mgr6775 ovens not functional
Could you describe your problem a little bit better?
Mar 02, 2014 | Maytag MGR6775 Stainless Steel Kitchen...
Maytag MGR6775 Ignitor is NOT problem but upper oven inop
Ignitor might be weak but appears to still work. Replace it anyway
Feb 21, 2013 | Maytag MGR6775BD Gas Kitchen Range
Maytag Gemini mgr6775 Lower oven takes FOREVER to preheat, but even when it says it is at 350, an independent oven thermometer says 310. It takes so long to bake anything.
Dear Scrapyourhea,
First ensure that your independent thermometer is working fine. It seems that there is problem with your heat mechanism. Normally this type of problems requires servicing....
Download the manual from given link and go through it. This will tell you the cause for the same.
http://www.retrevo.com/support/Maytag-MGR6751BDS-Ranges-manual/id/23649ci773/t/2/
Jun 07, 2010 | Ovens
Upper oven makes loud whooshing noise sometimes , like the gas ( propane )is blasting full tilt model mgr6775 ,mgr6875
Heatman101
Mar 11, 2010 | Maytag MGR6775 Stainless Steel Kitchen...
OVENS DONT WORK
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Dec 05, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Jan 04, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
Oven Problem
Yes, I replaced the lower oven sensor: it did not have continuity once disconnected from the rest of the circuit. That sensor transfers the power to the lower bake ignitor.
Nov 05, 2008 | Maytag MGR6775 Stainless Steel Kitchen...
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
64 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
