Question about Roper REX4634KQ Electric Dryer
Service manual rex5634kq1 - Roper REX4634KQ Electric Dryer
I have a Roper Dryer Model# REX5634KQ1. It just continuously runs. I have to open the door for it to stop. How do I fix it to stop on its own?
Listen to the timer and watch it whilst it is running. Are you sure it is advancing? Can you hear it ticking? If not, the timer is bad, and must be replaced. They are available on e-bay used, I've found.
Be blessed.
Jun 14, 2013 | Dryers
What is the capacity of Roper dryer REX5634KQ1, we received it in trade from my daughter's home and have no manual
While i am not sure it states the capicity here is a link to download the manual
https://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%203978913.pdf
Pretty much it will have a capicity that will handle a normal non overloaded washer
Gene
Aug 14, 2011 | Roper REX5635E Dryer
What year is a Whirlpool (Roper) dryer Model # REX5634KQ1 Serial # MM1558692
The second digit/character of the serial number indicates the year and the two digits next to it is the week the appliance was made. Refer to the table below.
In your case, the serial number is MM1558692. The second digit/character is M and the two digits next to it is 15. Based on the table, the machine was made on the 15th week of 2002 or April 2002.
Feb 11, 2011 | Whirlpool Dryers
My Roper REX5634KQ1 will not start. I finished a load and when i put the next in it would not start. I have checked the braker box and it is still on, I cleaned lint from the back and checked for any...
there is a onetime fuse in the back that burns out and the dryer will not stsrt until you replace it is small white fuse with 2 wires attached
Sep 21, 2010 | Roper REX5635E Dryer
Roper,model# rex5634kq1 Just quit working. wont turn on or anything
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Roper Dryers
My dryer will not shut off.
You need to replace your door switch.
Mar 05, 2010 | Dryers
I have a roper REX5634KQ1 won't turn on!
Thermal fuse is the problem , located on the blower housing . (small white thin piece with 2 wires attached ) Pt# 3392519 . You will have to remove the front panel to get to it .
Jul 13, 2009 | Dryers
I have a Roper Dryer Mod# REX5634KQ1. It just
There is a "one shot " thermostat that is probably blown. Part number 279816 which is a two piece kit. The part is located at the top of the heater housing.
Apr 07, 2009 | Roper REX5635E Dryer
Roper REX4634KQ Electric Dryer Logo
65 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
