Question about Dishwashers
8524569 KitchenAid won't fill completly
2 Suggested Answers
  • 77 Answers
SOURCE: Kitchenaid dishwasher 8524569 won't start
If the dishwasher won't start you likely have a bad fuse. Click on the link to download a video to see how to replace the fuse on your washer.
Appliance Repair
And to order the fuse just go to the Fuse Link
Posted on Mar 16, 2011
Why does my Kitchenaid dishwasher model 8524569 run so long?
It is likely the heater is not working effeciently and takes a long time to heat the water to the set temperature. Try and run the rinse cycle and see if that takes much shorter as this does not need to heat the water. Please provide the full model number- xxx. xxxx or KUD..etc.
Apr 28, 2014 | KitchenAid Dishwashers
How to start kitchenaid dishwasher
1-confirm power make sure breaker is not tripped or fuse is good and no tripped GFI's (no power obviously it won't work) 2-confirm water is on (the timer has a delay that it powers down during it's wait for the unit to fill with water 3-make sure the door is fully closed and latched properly (the door has a safety interlock to prevent the dishwasher from operating while the door is open -- think water sprayed everywhere) 4- beyond this if it is a new install and has never worked call your installer back
Apr 08, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
My dishwasher is filled with water and won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
May 07, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Appliance Repair
Mar 16, 2011 | Dishwashers
Dishwashers Logo
20 people viewed this question
Top Dishwashers Experts
Owen Barnes
