Question about Jenn-Air Kitchen Ranges
Jenn-Air dual fuel double oven range - oven wont work.
I have a 7 year old Jenn-Air dual fuel double oven range and the large oven won't work. The small oven won't keep a temp. Sevice Tech said it needed a new component board because the old one was blown and the repair would cost $874! He said that was too much and I should get another range. Is this something we can attempt on our own?
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
You can make the repair yourself. What is the model number?
Posted on Nov 10, 2012
  • 6 more comments
  • skhansen001
    skhansen001 Nov 10, 2012
    Hi Richard - the model # JDR8895AAS
  • Richard Roth
    Richard Roth Nov 10, 2012
    Thank you for the model number. You can order the part yourself and install it for under $400.00 Here is the part to order.http://click.linksynergy.com/fs-bin/clic... and the part comes with a 365 day, any reason, any part return policy. Just remove the back cover on the console to replace.
  • skhansen001
    WOW!! This is GREAT news! Thank You! Thank You! Thank You!
  • Richard Roth
    Keep me posted. I am always here.
  • skhansen001
    I will most definately do that. Can't thank you enough!
  • skhansen001
    skhansen001 Nov 14, 2012
    Richard - I ordered the part right after you sent the link to it, as well as two temp probs just in case we need them as well.
  • skhansen001
    The parts arrived this morning! So excited to attempt this repair on our own, can't wait for husband to get home.
  • Richard Roth
    Richard Roth Nov 14, 2012
    Glad to hear it. Keep me posted!
5 Suggested Answers
  • 2699 Answers
SOURCE: Jenn-Air dual-fuel range model SVD48600B dislpay
you need to change out the clock assy. part number 71001799 and it's around 200 bucks
Posted on Oct 02, 2010
  • 19 Answers
SOURCE: Jenn-Air Electric range clock display
The problem is likely bad capacitors on the clock module. I had the same problem on a similar oven and fixed it by replacing the capacitors on the clock module. Find someone who is good with electronics to help you. The parts will be a few dollars at most. See this link for more info: http://www.badcaps.net/forum/showthread.php?t=7902
Posted on Feb 04, 2010
  • 969 Answers
SOURCE: Jenn Air dual fuel oven. Oven is electric.
http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
  • 20 Answers
SOURCE: Oven won't heat up at all.
broiler on top of oven?? if so it might have a second ignitor that is working. Most units now with gas have an electric ignitor to start gas ovens. What they do is send electric current through an electric "wire", when enough current is flowing through wire to open gas valve the wire is hot enough to ignite the gas flowing over it. When you turn on the oven look at the burner and after 1 imute or so you should be able to see an Orange glow in bottom of oven if not I'm sure its the ignitor, if glows then probably oven valve is bad. I'd guess ignitor because most oven makers use this ignitor to mantain a warming temp (around 100 degree's) so since your display doesnt register over inital "start" temp of 75, i'd bet ingitor not coming on at all
Posted on May 21, 2009
Oven door won unlock
I HAVE A 10 YEAR OLD OVEN RANGE. SELF CLEANING IS IN THE LOCKED POSITION. I UNPLUG THE RANGE FOR 30 MIN THE DOOR IS STILL LOCKED
Jan 08, 2014 | Electrolux 30" Self-Cleaning Freestanding...
JDR8895AA Jenn-Air Double Oven free standing. Power was shut off during goutside generator maintenance; that was a week ago. No lights / noise on contol panel and 3 sec push on clock button doesn'
Not to be a smart aleck but have you checked the breaker box to see if the breakers are on also the standby breakers? Not sure how your'e wired though.
or reset to factory.... 1. Press and hold upper oven Keep Warm and Upper Cancel pads for 3 second. Should get a single beep. Then clock will show 12:00.
per repair manual Jenn-Air Repair-Manual-JDR8895AAB-JDR8895AAS-JDR8895AAW
Mar 06, 2018 | Jenn-Air JDR8895AA Dual Fuel (Electric and...
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven not heating up
I would contact JENN AIR about their range . Many problems with things we have never seen . SORRY
Jan 01, 2018 | Jenn-Air Pro-Style® JDS9860BD Dual Fuel ...
Uneven Temp in Ovens after Self Cleaning
in the users manual there will be a calibrating page. also self clean is hard on the oven a sensor that is meant to read 400 degrees has a hard time being accurate after 900 degrees
Dec 13, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven won't lock and self clean.
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Mar 01, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
914 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
