Question about Frigidaire Model PLMVZ169GC Microwave Oven
My microwave suddenly stopped working, indicated by not lights on the control panel display. I replaced the line fuse and the display lit up. When trying to start the microwave, the fuse immediately blew again. I've tested all 3 door switches, the magnetron fuse, both thermostat switches, capacitor and all appear to be functioning correctly. I noticed a burn mark on the control board around (what I think is) one of the resistors. Could this be making my line fuse blow upon starting?
  • Mitch Niedrach Nov 07, 2012
    Image of the control board burn around resistor
    Top Expert:
  • 14,553 Answers
Yes, that appears to be the inverter board that is for power for the magnetron.
NOTE: if that inverter is burnt the Magnetron may be bad.
My microwave suddenly stopped working, i - 11_8_2012_5_25_57_pm.jpgtypical Magnetron.
Posted on Nov 08, 2012
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave with load buzz and not heating.
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
It may be a problem with the transformer, but I suspect that less.
The diode is a fairly cheap fix, and the mag will cost more. The transformer may be pretty steep. But it's best to take it a step at a time.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 15, 2008
ginko
  • 19396 Answers
SOURCE: MICROWAVE NOT HEATING ANYTHING?
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on Apr 27, 2009
  • 561 Answers
SOURCE: microwave does not work unti, door slightly
this may not be the switch its self but its physical position in relation to the door acuator. either the switch needs adjustment or the door actuator or door itself. recommend certifed engineer advise on this problem.
warning: mircowave is a high energy, if doors are not seated correcly then energy may leak past door shielding and cause injury.
Posted on Nov 13, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Servicer with a PLMV169DCD Fuse blowing Problem
For future reference, we regularly repair such control boards and displays for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Here's the main service manual. Other versions are here and here.
It may be grease inside one of the switches or arcing conductors (usually due to opening the door while it's cooking) making it sticky.
This was made by Sharp, so the side panel should come off each interlock switch for inspection.
But looking at the schematic, the monitor switch cannot come into play under normal circumstances unless the door is shut and the secondary interlock (relay RY2 on the control board) is closed and (oddly, if the published schematic is to be believed) if the oven lamp relay RY1 is closed .
Everything seems to point to a bizarre problem like maybe an intermittent short of a wire to the chassis, perhaps where a wire passes through a hole or guide in the sheet metal.
Also, you might consider unplugging the hood vent motor and trying it.
Did you try it with the oven powered from another outlet?
Also be sure the neutral and hot are not reversed at the outlet and that the line voltage is correct.
Sometimes a loose neutral can be a factor. Test outlets in several area of the house to see if some are high and some are low. This can be dangerous, and the power company must be called.
If there is anything else on the same breaker, that can be a factor.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 29, 2009
  • 72 Answers
SOURCE: My Frigidaire microwave (PLMV169DCD) has recently
A used magnetron is not a good idea at all to try and you can not test a diode with a digital meter. 99.9% of the time your transformer will start burning the wire windings when it fails. Also a magnetron can test good and still be bad. Without being there and looking at this myself the best advise I can give is to check the door switches, and if they are good just replace the Magnetron and Diode. You can order reasonably priced microwave replacement parts here http://allapplianceparts.com/. The mags they sell are better than most oem ones and are cheaper! You can also pick out a replacement diode from them.
Posted on Nov 23, 2010
Glmv169gsb stopped working
You blew the fuse on the control board. Unplug it, remove the cover to expose the guts, and you should see a fuse. Replace it and try again. If it blows again, then you will likely find it cheaper to get a new microwave than have the control board replaced.
Nov 13, 2013 | Frigidaire GLMV169D Microwave Oven
Microwave fuse blows during operation
to much wattage on the same line
Mar 19, 2013 | Microwave Ovens
Kenmore microwave 911 41479791 no power?
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 24, 2012 | Microwave Ovens
Maytag microwave suddenly stopped working, overheated, nothing was cooking.
It is more than likely the magnetron is fried, to replace fuse! unplug microwave oven, remove top, "several screws" look to the right to the keypad control board, look down to a printed circuit board, clipped fuse should be near by, pop it out and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 22, 2012 | Maytag MMV4205 Microwave Oven
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
My microwave just stopped working. No problems until now. In the middle of cooking it just stopped. No display, no beeps, no bouttons working, no light inside. There is power to the outlet I can plug in...
for the microwave to stop suddenly it has blown its internal fuse this is located under the top panel of the unit it should be white with two silver tips ( ceramic fuse) in some cases the fuse will blow for no good reason on the other hand it can be a serious fault the fastest way to check this is to replace the fuse and re test the unit if the fuse blows instantly then bin the microwave if not it the fuse may have simply failed
best of luck always remember unplug the unit first and always replace with same size and and current fuse
please rank this advice if it helped you
Dec 28, 2010 | Kenmore 80402 Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Microwave stopped working while cooking. Is there a fuse?
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Jan 16, 2009 | Panasonic NN-H264 Microwave Oven
No Power - Emerson MW8773SL Microwave
LOOKK FOR FUSE UNDER SCREWED IN PANEL!
Dec 10, 2008 | Emerson MW8775W Microwave Oven
Frigidaire Model PLMVZ169GC Microwave Oven Logo
87 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
