Zanussi aquacycle zwf1632 all lights flashing green except filter flashing orange help
When I turn the machine on all lights flash green except the filter light which is flashing orange also the machine won't stop beeping until I turn it off.
  • 1462 Answers
SOURCE: zanussi electrolux aquacycle 1400 xc 6 fx1465 w
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Posted on Mar 21, 2007
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Posted on May 31, 2007
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
TheMobilian
  • 8220 Answers
SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Posted on Dec 31, 2009
SOURCE: hi my zanussi zwf1432s stopped halfway through
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Posted on May 05, 2010
Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
I have a zanussi zwf1432w aquacycle.
Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
Can you help.
Cheers
Apr 05, 2011 | Washing Machines
How do you take the filter out of a zanussi aquacycle 1100.i have tried turning the cap and i cant move it at all.
I had the same yesterday as the orange filter light keeps flashing, if it is at the botom of the front of the machine, white plastic? I managed to unsrew it with the help of a pair of pliers, you can get a better hold on the filter screw.
Hope this helps
Jun 10, 2010 | Washing Machines
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
