Question about Manfrotto Bogen 732CY M-Y Carbon Fiber Tripod
Leg stuck on Manfrotto 732CY tripod
Both of the bottom 2 sections (from clip B and C down) on one of the legs are stuck on my tripod. What is holding inner parts to the leg in place?
  • 685 Answers
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
www.bogentripodparts.com
bogen and manfrotto are the same company
Posted on Dec 12, 2012
5 Suggested Answers
devocap
  • 201 Answers
SOURCE: ART055 manfrotto pro tripod
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Posted on Feb 04, 2008
  • 63 Answers
SOURCE: i need a lower leg clamp for my 190xb manfrotto
You can order the lower leg clamp as a part from http://bogentripodparts.com/parts/190XDB.htm
Follow the link and check for your part number.
Hope this helps,
Andrew
Posted on May 26, 2010
  • 685 Answers
SOURCE: Broken leg clamp, Where can I buy a replacement part?
Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part
Posted on Jun 22, 2010
  • 175 Answers
SOURCE: Broken Leg Clamp - Manfroto 055SB Tripod
For parts, try www.bogentripodparts.com
Posted on Nov 12, 2010
Manual for Manfrotto 732CY tripod
Try Googling (Manfrotto)(732CY)(manual) without parens.
Aug 23, 2015 | Manfrotto Bogen 732CY M-Y Carbon Fiber...
Tripod leg stuck
loosen the allen head screw for that legs snap lock
Mar 13, 2013 | Manfrotto (190XB,128RC) Tripod
Trouble opening legs of my manfrotto tripod
Manfrotto have great warranties. If it is new, send it to Manfrotto to repair/replace the parts and make it whole again. If parts are worn it will be hard to tell you how to fix it without pictures, or know which model tripod you have.
Dec 14, 2012 | Photography
Manfrotto 685B locking problem
I had the same problem with the Manfrotto 685B, and it was due to the grease from the middle section leaking into its locking mechanism. I fixed the problem by: 1. Detach the middle from the bottom section by twisting the metal hub between them counterclockwise. 2. Wipe the grease off from the middle section's locking mechanism, especially from the three gray protrusions. 3. Use a bit of dish detergent to degrease the inside shaft of the bottom section. 4. Dry thoroughly. 5. Reassemble the section back, pressing the monopod release lever to facilitate the insertion. Reclose the metal hub. Ha! Fixed!!1!1!!eleven1!!
Feb 28, 2012 | Manfrotto BOGEN 685B Neotec Deluxe Monopod
Broken leg clip on Manfrotto Modo 785B tripod the head is non-removable on this model and I don't want to have to replace whole tripod so is there somewhere I can buy a new leg clip or get it...
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
May 09, 2010 | Photography
I need a new leg section for one of the legs on the G1257 tripod. The section I need is the lower section of the 3 in the leg. Do you have 1 in stock?
In the US, I think Bogen is the official distributor of the Gitzo products.
Manfrotto Distrubution
ATTN: Service Dept.
565 East Crescent Ave,
Ramsey, NJ 07446
201-818-9500
Hope this helps..
Andrew
Apr 03, 2010 | Gitzo G1257 Tripod
I have a Manfrotto 058 tripod. One leg wont hold weight & retracts under load. This model uses a quick release lever at the top of the leg to control the telescopic height of each leg. How can I repair...
If you notice, the legs locks are attached to bothe the upper part of the leg and the sloghtly smaller diameter lower. Take a socket (8mm I believe) and tighten the lower 2 nuts to the bottom of the leg lock.
Feb 12, 2010 | Bogen Communication Bogen Manfrotto 3030G...
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Broken Quick Release tabs on one leg section. Can we change the leg section and where can I purchase this part in Montreal, Canada?
Broken quick release on a Manfrotto 728B digi. What is the best and most economical way to fix? Is there a repair or service provider near Somerville, NJ 08876?
Dec 05, 2007 | Manfrotto Digi 728B Tripod
Manfrotto Bogen 732CY M-Y Carbon Fiber Tripod Logo
284 people viewed this question
Top Manfrotto Photography Experts
JP Services
JP Services
Tom Chichester
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
