Question about Health & Beauty
Install battery for remington ms3c-0004 razor
How to remove cover to access battery
3 Suggested Answers
  • 3 Answers
SOURCE: I need to replace batteries in Remington wdf 3500
Have just opened the same model -
First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
Posted on Jan 31, 2009
VtToolMan
  • 704 Answers
SOURCE: batteries for ms5500
Give the folks at electricshaver.com a try. I tried to look up the replacement batteries for your shaver, but didn't find your model number listed on their site.
However, you can give them a call and see if they have them available, as many shavers use similar batteries, you just have to know the cross-reference list to figure it out. There phone number is 1-888-476-1785.
Normally I can provide the replacement part numbers for electric shavers and provide a link to the parts list for them/
Hope you find this Very Helpful and best regards!
Posted on Sep 24, 2009
I need to replace the battery in a Remington women's razor model wdf 1600
  • Open battery compartment
  • Note correct polarity and remove
  • Install new battery
  • Close battery compartment
  • Test operation
If the razor does not work, the replacement battery may be defective
Jul 12, 2016 | Remington Health & Beauty
Remove battery cover on razor mx 350
The battery installation guide is available here
http://www.razorama.com/razor-installation-guides.html
It shows how to remove the covers.
Jul 30, 2012 | Razor MX350 DIRT ROCKET - BLUE
Installation of battery for 950 remington
You will find the correct battery at shaveroutlet.com. You will need two. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Open shaver by removing two screws on the back. Then remove back cover to access battery compartment. You will need to 'unsolder' the wires from the ends of the batteries. Once removed, solder the new batteries to the wires.
Aug 23, 2011 | Remington Titanium Microflex R-950...
Opening a remmington ms2 150 or ms2 300 razor to replace the batteries
You will find the correct battery type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
To open the shaver you will need to gently pry off the rubberized grip on the front of the shaver. You can then access and remove two screws near the bottom. You will also need to loosen the flat metal clip plate at the top that is under the cutters. Once this is done, you can open the shaver and access the batteries
Jun 15, 2011 | Remington Health & Beauty
Remington Electric Shaver..How do I disassemble a Model XLR 900. 8BF2-1C. I want to replace the battery.
Unfortunately these rechargeable razors are not designed to be easily serviced by the home user.
Changing the battery will definitely involve a bit of searching for the multiple screws which hold the case together and then disassembling the case to access the battery compartment. Just watch out for any screws which may be hiding under the rubber padding pieces. You will then likely be required to desolder the old battery out and then resolder your new battery back into place.
Here is a link to a site which describes the various methods for disassembling battery powered shavers:
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Here is a link to a replacement battery available for your model:
http://www.batteryweb.com/cordlessrazordetail.cfm?ID=238
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
May 14, 2011 | Health & Beauty
What is the replacement battery for R9100 razor and how is it fitted
You will find the correct battery type at shaveroutlet.com. See link below. You will need 2
To change batteries, remove three screws on back. The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body. Remove back cover. Inside, remove the metal clip that covers the batteries near the bottom of the shaver. Unsolder the batteries from the wires. Solder in the new batteries.
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 16, 2011 | Remington MicroFlex R856 Electric Shaver
I HAVE A REMINGTON TITANIUM R9500 WASHABLE RAZOR. I HAVE NEVER BEEN ABLE TO HOLD THE CHARGE FOR MORE THAN 2 OR 3 SHAVES. NOW I AM UNABLE TO CHARGE THE RAZOR OR RATHER IT WILL SHOW 60 MINS AND AS SOON AS...
The batteries need replaced. You will find the correct batteries at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Remove three screws on the back of shaver to take off back cover. You will need to remove the trimmer to access the screw at the top of the back of the shaver. Once back is removed, you can access the batteries. One of them will have a diode 'glued' to the side of it. Use a razor blade to cut it away from being stuck to the sie of the battery. The batteries are adhered to the circuit board but can be gently pried away. Remove the black tape from ends of batteries if present and then unsolder the wires from the batteries. Solder in the new batteries and reassemble.
Charge shaver for 24 hours when repair is complete.
If you are not capable of doing this repair youself, shaveroutlet.com can do it for you. See link below
Dec 19, 2010 | Health & Beauty
R-9190 Electric Shaver: The razor is used 20 seconds a day and used to go ...
The problem is almost certainly the batteries. You can access the batteries by removing the screws on the back and taking off the back cover. You will find batteries at shaveroutlet.com. You will need two batteries. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
May 05, 2010 | Remington R-9190 Electric Shaver
Razor not working
What is brand and model #? Remington R650? If it is, it should work with charger plug on without using battery. If it does not work, the battery may be shorted. To take out the battery please refer my procedure I posted in another battery exchanbe trace. It holds by 4 hinden screws under the red plastic cover. I did disassemble the whole unit from top down just investigate everything. To remove trimer may not be necessary though.
Aug 06, 2009 | Remington R-650s Electric Shaver
Remington M8221 Help
STEPS
• Thoroughly clean the razor cutter area
• Pull off (straight out) cutters and lay aside
• Release spring clips and remove
• Gently pry up and remove rubber boot
• Pry case open starting at cutter end and bending up toward connector end
• Thoroughly clean razor interior area (blow out)
• Pull up motor and remove black oscillator bars
• Pry up the circuit board by releasing the cutter-end catch using a small tool to push it in while prying gently up on the cutter-end of the board and bending up
• Clean the board and turn it over
• Note battery polarity and mark on board if not present already
• Unsolder the battery tabs using unsolder braid. Be careful not to short the electrical circuitry as the batteries are electrically LIVE at this point.
• Remove the old batteries and fully clean off the circuit board solder-pads using unsolder braid.
• Mark the installation date on the new batteries in a place where it will be visible
• Install new batteries, making sure the polarity is correct (cut the tabs to a correct length if they extend too far through the circuit board)
• Solder the battery tabs being careful not to short the electrical circuitry as the batteries are electrically LIVE at this point
• Re-install the circuit board and other parts following the procedure in the reverse order (be sure to put a soft rubber pad over the motor to hold it firmly in place when the upper case half is snapped in place)
• Before installing the metal retaining clips be sure that the rubber boot is fully free and not pinched between the case halves
• Finalize the assembly by reinstalling the cutters and screen
Feb 24, 2008 | Remington MicroScreen Intercept M-8221...
Health & Beauty Logo
153 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
