Question about Maytag MVWC400XW - CentennialR High-Efficiency Top Load Washer
Doesn't advance from wash to spin successfully, think it may have something to do with draining very slow. no clogs that I could find from drain tube all the way to the pump that I took off and checked.
  • 35 Answers
It sounds like the wash timer has gone bad,you'll have to replace it, alot of the dealers wont sell just the timer moter.
Posted on Nov 08, 2012
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
Dishwasher filled and does not drain. I think the dial is faulty; however, how do I drain the water.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher won't drain when cycle is complete. Not even when press on the Cancel/Drain button. Engine starts working (at least sounds like something is going on) but not water goes out to the sink...
Hi
Daniel
Aug 30, 2011 | Dishwashers
Dishwasher started to wash then it stopped. Now there is water standing in the dishwasher and won't drain.
Hi
Daniel
Aug 22, 2011 | Kenmore 24 in. 16022 Built-in Dishwasher
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Daniel
Aug 14, 2011 | Dishwashers
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Aug 06, 2011 | Whirlpool Dishwashers
Washer fills and agitates but wil not empty or spin. I tried to bypass the lid switch and still same problem. How do I check the timer.
Hello there and thank you for choosing fixya
OK first lets get back to the basics
First investigate these things fully
It doesn't drain dot_lineone.gif 1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
3. TIMER OR CYCLE SELECTOR
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. THERE IS NO REPAIR FOR THE TIMER
Aug 04, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
Dishwasher stopped in the draining cycle and will not start back up, even after turning thye daqil to start a wash
Hi
Daniel
Jun 15, 2011 | Frigidaire 24 in. FDB221RF Built-in...
Maytag MVWC400XW - CentennialR High-Efficiency Top Load Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
