It turn on but in a few minutes it turn off like it lost power
  • Computers & ... Master
  • 27,725 Answers
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Posted on Nov 08, 2012
I lost my internet connection, how do I get it back?
turn the power off for a few minutes then turn it back on
it will take a bit of time as the unit finds all of the IP addresses
Nov 26, 2017 | Internet Computers & Internet
My samsung galaxy S4 by t-mobile has lost its sound. What can I do to get it back?
My S5 lost it's sound too..I just powered mine down..& left it off for a few minutes..then turned it back on..& THAT WORKED for ME!...:)
Hope it a success for YOU!
Ps. Mine is US CELLULAR.
Jun 19, 2014 | Cell Phones
Suddenly lost power in any forward gear or reverse after 600 mile trip in 1994 Roadmaster estate. After leaving engine off for a few minutes and turning it on, it moves forward/back for a few minutes...
Will it idle normally? Will it move in gear slowly? If it is only affected when you try to move faster it could be a plugged catalytic converter. Or a bad throttle position sensor. Not sure.
Feb 20, 2010 | 1994 Buick Roadmaster
We lost power and the tv was on at the time the power went off when power returned the tv said no signal all other tvs in house work
if there is a stanby switch for the remote, turn it off. wait for a few minutes then turn it on. operate the remote.
Jul 17, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Engine only cranks at times but doesn't start for a few minutes.
There is is something called a pgmi relay that goes bad. Its under the dash, left of the column. It is rectangular, and says pgmi on it. It is fairly expensive. Can only get it from Honda.
Mar 26, 2009 | 1999 Honda Accord
3 beeps every few minutes
That maybe a memory beep code. Turn it off and remove and re-insert the memory modules on the mainboard.
If this doesnt work, get back to me.
Feb 13, 2009 | Apex Computer Technology Apex Power Supply...
Loss of electrical power
replace battery and check post. Your popping sound could have been a fuseable link. check the one thats leading to the starter.
Jan 26, 2009 | 1994 Ford F350 Crew Cab
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
