Question about Toshiba Satellite L655D-S5093 Laptop
I have a toshiba satellite l655d-s5093 with windows 7 and it shows pxe-mof exiting intel pxe rom... no bootable device -- insert boot disk and press any key. any help to restore my computer? Thanks
  • Toshiba Master
  • 7,627 Answers
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally.
IF THAT FAILS, try F-8 during pre boot, try to get to safe mode, or F12 to enter restore /recovery. After each try cold start, remove battery during this process.
Posted on Nov 09, 2012
4 Suggested Answers
SOURCE: check cable connection PXE-MOF: exiting intel PXE ROM No bootable device -- insert boot disk and press any key
Hello.
-Possible corrupted BIOS or failing hard drive.
- When you get the error, try to insert the Windows installation CD that came with the laptop then press any key. Check if that will fix the problem.
-You can also check memory module. There are times some hardware are causing conflicts to the system. Try to remove memory module and check for the error again. If removing the memory module resolves the problem, it's a faulty memory. If not, then it could be a problem with the hard drive. Be sure to take necessary precautions before removing parts on your laptop.
For guide in removing and installing devices on your laptop, you may visit http://support.toshiba.com to download the manual for your laptop.
- Last option is to reset the BIOS which requires removing the CMOS/Lithium battery for 5 seconds and putting it back. You can do this by opening the bottom panel of the laptop which requires an expert to do it.
~~Hope this helps.~~
Posted on Nov 29, 2011
  • 1623 Answers
SOURCE: toshiba c650: chek cable connection!
your hard drive is corrupt or it is broken
Posted on Feb 13, 2011
  • 118 Answers
SOURCE: toshiba c655: chek cable connection!
Maybe the cables are not connected, they may be disattached to the hard disk or optical drive. You can try opening the bottom of your laptop, it usually has a hard disk vent, when you unscrew the cover, you'd see the hard disk, and you could connect it. If this doesn't help, the boot manager of the OS might be corrupted, you should insert your setup disk and choose start up repair.
Posted on Mar 15, 2011
How do I fix this error messageFor Athros PC/E Ethernetnet Controller v2.01.9 12/15/09 Check cable Connection! PXE-MOF:Exiting Intel PXE Rom No bootable device--insert boot disk and press any key Inte
That error comes up when the computer cannot find the hard drive or any other device to boot from so it looks for a network booting program and when it cannot find that, the error shows up. REPLACE YOUR HARD DISK,
Aug 01, 2014 | Toshiba Satellite Computers & Internet
Ok 1. acer; aspireone 2.Wont boot up 3. PXE-E63:Error while initializing the NIC 4. PXE-MOF Exiting Intel PXE ROM 5. No bootable device--Insert boot disk and press any key. Thic pc has vista on i
switch to boot devices (F2....F8,)do this as soon as you press power button.keep pressing to bring up bios disable all bootable items in list except cd rom.give this a try good look
Dec 12, 2013 | Acer Aspire Computers & Internet
No bootable device
when ur computer starts,start press the f8 key again again after that there will come so many option chose repair or restore option.
NOTE: it may delete your newly installet software. choice is urs then don't blame me
Jun 07, 2013 | Toshiba Satellite Computers & Internet
Wont go past first screen
First try this unplug from AC, remove battery, plug in try to boot normally. If that fails Open BIOS, Boot Order or the BOOT MENU, Boot from HDD first, and save changes and reboot, if that fails try a system restore/recovery.
Dec 09, 2012 | Toshiba Computers & Internet
My gateway says "Check cable connection!PXE-MOF: Exiting Intel PXE ROM. No bootable device--insert boot disk and press any key". What should I do?
Sounds like the hard drive isn't getting power,the data cable to the drive isn't connected,or the drive controller on the motherboard is toast(I'm a novice tinkerer,not an expert).
May 25, 2012 | Computers & Internet
Toshiba c655: chek cable connection! PXE-MOF:Exiting Intel PXE ROM. No bootable device--insert boot disk and press anz key
Mar 15, 2011 | Toshiba Satellite A60 Notebook
My problem is I am getting this error whenever I boot my laptop "PXE-MOF:Exiting Intel PXE ROM. No bootable device -- inset boot disk and press any key -
you are getting this message because the boot sequenece is loading from PXE first, you can go into the BIOS and change the boot sequences order to hard drive first, CD Drive second and then PXE
Jan 05, 2011 | Toshiba Satellite C650DST2N02 Laptop
Toshiba Satellite L655D-S5093 Laptop Logo
119 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
