Question about Toshiba Televison & Video
Channel set scan - Toshiba Televison & Video
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Does not scan or does not store? The auto program or scan feature is in the main menu in setup area and done with the original remote.
Posted on Nov 08, 2012
How can i set the channels to scan
This is usually part of initial set up but you can return to that procedure at any time to scan or rescan channels.
Sep 11, 2016 | Proscan Televison & Video
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
I have connected the tv to cableand I can only recieve channels 2,4,5,9 & 13. How do I set up the tv to receive the remainder of the channels? Thank you
do a channle auto scan, you need to select CATV in order to scan for cable channels. after the scanning process, all the channels you can get should be on your set.
Mar 19, 2011 | Sharp Televison & Video
I want to go to channel 3 so i can go on cable , but the remote doesnt let me !
Hello; All TV's made in the last 20 years are computer controlled. The TV wants you to do a "scan ", so it can MEMORIZE all active channels. IF you are connecting your set to a cable BOX or OTHER, the set can only SEE the Channel 3 output from the boxes. No scan will work when doing this! In this case don't expect to be able to use the channel UP or Down keys on the set or remote, because the set does not know any channels due to no memory of a scan. You can, however key in the channel # and the set should go to that channel, unless the set is defective. John
Dec 19, 2010 | RCA Televison & Video
I am setting up my proview pa-32jk1sa, for the first time. we have dish network, but all my tv says is please scan channels. i have my coaxial plugged into hdtv, and also went to settings for hdtv and set...
chances are that your reciever is outputting conventional NTSC .. not high def ... so you would scan for standard channels not hdtv .. if chanel selection is done by the satelite reciever then the scan will only find one channel 3 or 4 usually (or better yet you can use Svideo or component oututs if it has them .... if the receiver is a block converter that uses the tv to tune channels then you should get more channels detected ..
Jun 24, 2010 | Proview PA-32JK1A 32 in. LCD Television
Can't get cable stations
you have to go into the menu and set for cable then scan for active stations.
Mar 15, 2008 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
