Question about Asrock G31M-S Motherboard
It is stoped after 1 manit from boot - Asrock G31M-S Motherboard
  • 3,799 Answers
Check CPU fan is running and that the heat paste on the CPU is still sticky.
Posted on Nov 08, 2012
3 manit stop 7 minutes working o general wall mounted 3 ton
Sounds like a safety is tripping. Low pressure/high pressure/thermal overload. Be sure outdoor fan is running. Good Luck@@
Apr 05, 2017 | General Heating & Cooling
My lg70 321 is stuck in safe mode ,i cant get the key board up on the screen and i tryed a reset and it didnt work , .it allso says settings has stoped what do i do to fix this?
Hi Jeannette,
Computer boots into safe mode when there is too much damage in the normal mode to be fixed, this is a special mode designed for technicians to fix internal software issues.
you can use msconfig to try to boot to normal mode, but that might put the computer in a NO BOOT LOOP in which case you will loose all the data on the computer.
i suggest calling an expert right away. call 1-877-805-1027 for expert assistance.
Aug 15, 2015 | Computers & Internet
Maintenance ink pr
Can you please explain what is happening, are there any error messages or what happens when you try to print etc.. the more details the better. Thanks
May 31, 2013 | Brother MFC-9320CW Color Laser Printer -...
My hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay . this problem used to happens from time to time...
my hp ml370 g5 server is not booting when i switch it on i only hear the high sounds of the fans with out stoping till i fed up and power off it manulay .
Jun 27, 2011 | HP ProLiant ML370 G5 Server
When do you need manitance on the timinh belt?
You can check your maintance schedule in the owners manual. But, if you don't have one the dealer would tell you for free. Most cars and trucks with timing belts recommend replacement at 30,000 miles. You should do this to save trouble down the road.
Sep 02, 2010 | 2006 Toyota Camry
My eeepc 4g does not work it stoped instant .i can't start it any more help .observation : i've changed the ram from 500 mb to 1 gb . please send help me winzard2kk@yahoo.com
you must re-install the OS either from F9 at boot-up or from disc via rom drive.
press power button down for 5 secs or more to see if this shuts you down cleanly and then thus enables you to re-install from the hard drive.
F9 only works ever other boot--ok
Jan 04, 2010 | ASUS Eee 4G Notebook
When started will not throttle or dies afetr a minute of running
i love the manits tiller they are very strong and dependable.....they are the same as an echo tc210 i parts will interchange.
your issue is more than likely a plugged fuel syetem, flush the fuel tank, replace the tygothane fuel lines with echo 90014 fuel line, and tank grommet, clean and rebuild the carburetor, install a new tank vent for good measure....untill should spring back to life.....hope this helps and good luck ;)
Nov 24, 2009 | Mantis 2-Cycle Tiller
My dvd just stoped playing movies and cdvds
Power down, remove battery, remove the drive. Power up and boot fully, then shutdown. Reinstall the drive, then power up and see if it read the DVD. Also clean the lens. If still don't work, replaced the drive.
Nov 16, 2009 | Gateway MX6956 Notebook
2005 volvo s40 t5 how to reset oil light
turn the key on to position 1 preset miliage trip button anh hold for 2 second release and turn key to position 2 hold within 4 secods and hold til manitance info clears.
Apr 16, 2009 | 2005 Volvo S40
Battery keeps going!!!!!!
Partsexpress.com
don't forget to leave positive feedback!
Oct 21, 2007 | Orion Xtreme XTR12 Car Speaker
Asrock G31M-S Motherboard Logo
22 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
