Question about Frigidaire GLTF2940ES Front Load Washer
How do I get my waxher to show error code. It keeps shutting off just after turning on water
  • Official Brand Answer
  • 4,342 Answers
Hello - Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Posted on Nov 09, 2012
My AEG OKO LAVAMAT 72640 keeps stopping mid cycle and flashing error cod E10 what can I do?
The water Supply
1. First, check that the tap is not accidentally turned off.
2. Check that the gray water inlet hose is not squashed or kinked lies.
3. It is also possible that the filter is clogged in the supply hose. Close the tap and disconnect the hose. Here is some pressure on it, so keep a towel handy. Check the filter that output waterklraan, and clean it if necessary.
Apr 16, 2016 | AEG Washing Machines
Help with error code
Before calling service technician, open following link for Rheem tankless troubleshooting resources including error codes and typical maintenance:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Mar 20, 2012 | Rheem Tankless Hot Water Heater...
Cold water will not shut off and keeps running into the machine and then machine shows error ( IE)
'IE' for LG's decodes as 'water inlet error' which is quite right!
This is symptomatic of a malfunctioning water control valve- it's not closing completely- its default/no power state. Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Apr 06, 2011 | LG WM1812C Front Load Washer
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
Washer keeps giving FH code. no restrictions in water flow. maybe a sensor?
After 30 seconds if the control does not detect water entering the machin then the water valve will be shut off and the error code show.
also:
If the control has turned the water valves on and 8 minutes pass and the flow meter has measured roughly 10.1/2 gallons of watergoing through it, but hasnt detected the pressure switch being triped, the water valve will shut off and the fh error code will blink
First push the PAUSE/CANCEL key twice to clear the control
If no water in the unit do this: - Make sure the valves at the water source are turned on fully.
Inspect for plugged or kinked inlet hoses or maybe plugged screens in the inlet valves
Also inspect the water valves operation
If there is water in the washer: - Inspect the drain pump, and the pressure switch hose for any kinks or rips. also check for proper connections with that hose to the tub and pressure switch.
may be a siphon problem read your manual on that.
Check all wireing harness connections to the Water valves,pressure switch, drain pump, flow meter, and the ccu or cental control unit
Inspect all hoses for any leaks
Replace the failed component if found ...
hope this helps
Jan 28, 2010 | Maytag Washing Machines
I loaded the update for my blackberry and got an error jvm error 102 and now the phone will not charge or turn on i have tried a new battery and that does not work. It does not show like its charging or...
Sir, The system checked the COD files in the device for modification and determined that a problem exists with one or more COD files.If all loads fail, a build process error might occur (a problem exists with signing the COD files).If a user action on the device resulted in this problem, the reset cycle is continuous because the code in the filesystem has been corrupted. The only recovery method is to wipe the device and restore a new system.
Jul 14, 2009 | RIM BlackBerry Storm 9530 Smartphone
Xerox DC12 Error code 9-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
Frigidaire GLTF2940ES Front Load Washer Logo
20 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
