Question about Sanyo Televison & Video
Half of my screen is very dull and faded
When problem started after a few minutes after warming up the tv would have a perfect picture. but now only half of the picture is visible
  • Sanyo Master
  • 8,617 Answers
The Tcon is the most likliest item that will cause that.
Posted on Nov 08, 2012
  • 286 Answers
SOURCE: Picture full of lines and flicker
Zdenko did an excellent job. Voltage regulators and the capacitors on the main boards and in the power supplies are always suspect. Some times you can narrow down the culprit buy purchasing a can of freeze spray. Let the TV warm up and try freezing suspect components to see if this causes a reaction. Thermal problems can often be found in this way.
Of course, if you're not able or willing to replace components on the circuit boards, you can always replace the main board or power supply board after determining which is causing the problem. These parts should be available at your local Viewsonic service provider at a reasonable price.
Posted on Feb 14, 2008
jomabug76
  • 1148 Answers
SOURCE: fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Posted on Oct 05, 2008
DRACO A5OG
  • 22 Answers
SOURCE: Intermittent picture, blue line
I have a Vizio P42HD but once it is taken apart, it is all LG components.
It is your Power Control Board 6871qch038a. The solders are so small it isn't worth trying to re-solder.
Spoke with PartStore.com, rep stated 6871QCH038C (038C) is the superceded replacement for the defective prone OEM 6871QCH038A (038A). They and others offer the 6781QCH060Q (060Q) for $50 - $100 more. I opted for the 038C, but I was concerned about the title of the part which states "HAND INSERT"... PartStore.com rep stated it is in fact a board and there is no soldering needed, just "plug and play". DONE, paid only $120.95 + next day shipping for $29.95.
Since I took the TV apart before, it was a breeze and took about 2 hours, start to finish.
Important note, remember to remove the two 1" square spunge type heat sinks/pads the new board needs those for a proper installation and protection of the certain component.
Also you need two small zip ties to replace the ones you are going to clip off.
Added Bonus, the new board fixed other issues:
1. At times I would get a squeegly red line go across the screen. I thought it was the source (cable) but it is gone now.
2. Screen Shift, when I use the XBox for Games or DVD/HDVD the screen would shift. Very annoying, prior to swap out, recently the screen started to shift watching cable. Now it is no-longer an issue.
I am really pleased with my DIY repair and wanted to share.
The damn Vizio Out of Warranty Service wanted $360 for a service call which included the part for $125 plus they take my bad board for exchange.
6871QCH038C $120.95 http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenit h/6871QCH038C/New.aspx
Over Night Shipping #29.95
Posted on Dec 31, 2008
  • 3 Answers
SOURCE: Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Posted on Feb 20, 2009
SOURCE: Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Posted on Apr 08, 2009
Won't turn on screen until it warms up
i had this problem with my samsung a while back same symtoms everything and after hectic research i replaced a few blown(swollen) capasitors on the power supply and bam! it worked? its worth a try hope it helps
Aug 09, 2012 | LG 32LG30 32 in. LCD HDTV
One half of the lcd tv loads fine, picture is perfect. The other half of the tv screen appears to struggle to warm up and appears much darker. In fact the image lingers when one program ends and another...
How old is your LCD TV?
From your description of the problem. It appears to be a moisture related. As the TV is ok after a while.
Power off your TV before carrying out next steps.
I would check the wiring connections first and see all connections are good. Also vacuum clean of dust using a brush is recommended.
Secondly would use a hair dryer to blow hot air into to TV unit via the exhaust vent. Just ensure that power is not switched on.
on your TV when you use the hair dryer.
i would also suspect a possible bad joint of a component on the mother board. A visual inspection is required to see the motherboard.
Also a component failure is a suspect due to aging..
You need to evaluate if it worth repairing the TV. Repair cost can be prohibitively high.
hope that helps. good luck.
Sep 10, 2017 | Wharfedale DVD-M3 DVD Player
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
61 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
