Question about Proscan 47LB45H 47 in. LCD TV
I have a line at the bottom of the screen about an inch up. How can I get rid of it without spending more than the TV is worth.
    Top Expert:
  • Proscan Master
  • 14,553 Answers
A reboot or factory reset if possible will not help with that issue---bad connection somewhere or bad display panel (screen unit).
Posted on Nov 08, 2012
5 Suggested Answers
  • 814 Answers
SOURCE: I have a 32 inch Proscan LCD tv. Is there any way
I found this solution on the PROSCAN website. www.oncorpus.com.In the customer support section, under manuals for you model of television. I hope this information helps you with your problem. Press MENU on the front panel or on the remote control and then use the up and down arrows to select the AUDIO menu.Press the enter button to enter the function.
1. Use the up and down arrows to select what you want to adjust in the AUDIO menu.
2. Press ENTER button to select it and then use the right and left arrows to adjust
3. When you are satisfied with your adjustment, press MENU to exit the main menu.
Audio Mode.
Posted on May 21, 2009
  • 362 Answers
SOURCE: 3 light x-lines across TV screen
Proscan is now owned by RCA, you will need to call the number below and explain the warranty info.
If your concern is urgent, we can be reached by phone at 877-794-7977. Our hours are 8AM - 8PM Monday - Friday EST and 10AM - 7PM EST on weekends.
Let me know if I can assist further. Please rate this solution.
Lone99star
Posted on Mar 02, 2009
walesarumi
  • 6993 Answers
SOURCE: how do I hook up a DVD player to a proscan 32 inch
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Posted on Apr 18, 2010
jdvillanueva
  • 2098 Answers
SOURCE: bought a 26 inch proscan from Costco on line. Tv
Hi sglassgold,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated. I would advice also to replace the entire power supply for your convenience if finding technician there is not possible.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 14, 2011
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Plzzz help me!!!!!
Your defective has defective parts on horizontal section. You need to bring the tv to expert technician,
Jul 26, 2009 | RCA 32F531T 32" TV
The tv circuitboard has a 1\8 inch hole in it
The board it self is probably toast but if the set is a newer model and expensive then it might be worth fixing with a new board. My rule of thumb is not to spend more then 50% of the replacement cost to repair. Try and get a rough estimate for free and decide if it is worth it. Good Luck
Jul 24, 2009 | Televison & Video
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
Black line problems
Some components in the vertical deflection amp have been going out of spec with age.
The set may no longer be worth to spend money to service it because of its age. However, if you wanted to invest the money, the set is serviceable. Considering its age, the CRT may be soft, and there are many other older components that can soon fail.
I would be considering a new set.
Jerry G.
Apr 18, 2008 | Toshiba 36A40 36" TV
Horizontal lines and screen bounce
These sets have capacitors that will go bad, but without a good ERS meater that tests these in curcuit you could be spending a lot of time doing nothing, But the most common is to find the 9 volt reg on the signal board and change all within a 2 inches of that regulator
Feb 07, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Dec 29, 2007 | Philips 32PW6006 32" TV
Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
Nov 15, 2007 | Mitsubishi CS-27205 TV
57 inch sony kp57wv700
I had the same problem and just listed the dang TV on craigslist cuz I didn't want to spend $$$ to fix. I searched the internet to see if I could somehow fix it (not mechanically inclined whatsoever) but low and behold, I did it!!! It's so easy, the worst thing about it is unscrewing the screws! Just be careful when you finally get done unscrewing everything, be cautious when removing the bottom front away because if you yank too hard, there are wires connected to the power buttons in the front. Here it is: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Dec 22, 2006 | Sony KP-57WS500 57" Rear Projection...
Proscan 47LB45H 47 in. LCD TV Logo
26 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
