Question about ASUS K40IN Notebook
Suddenly keys "ESC", up, DOWN and "p" stopped working. No water was spoiled, nothing was done. At the evening they worked, in the morning not. I might have accidentially pressed some keys like Window sign, or Fh plus smth (in darkness, did not see what) but could that stop some buttons from work ...?I do not know what to do, restart does not help
    Master:
  • 545 Answers
It might be a loose keyboard connection. Try dusting debris out from the keys. Next, try re-seating the keyboard cable/ribbon to the system board.
Posted on Nov 09, 2012
SOURCE: number issues on screen
do you have num. lock on? mine did the same a few days ago and that was my problem
Posted on Jan 02, 2009
alexvelez052
  • 40 Answers
SOURCE: my asus laptop wireless switch does not work
well you erased the drivers for the fn keys and the wireless go to the manufacturer website and type the model of if possible laptop or motherboard and download the drivers for wireless and media controls
Posted on May 07, 2009
  • 52 Answers
SOURCE: problem in opening the wireless connection and the Cd installation cannot open also
Sounds like you have removed the hotkey functions.
You will need to go on here,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Find your model in the A3000 series and download both of the "Utilities" in the "Other" section and install them. Should be ok after this is done.
Craig
Posted on May 25, 2009
  • 205 Answers
SOURCE: keyboard does not work properly
If your notebook gets very hot in daily use, then it affects your keyboard's rubber spacer.
try to reinstall your windows and check it. sometimes a software error cause the same problem by being make the kernal busy and not unresponsive. If you don't want to reinstall just use a bootable linux cd and check your keyboard function.
Hope it'll help you anyway
Posted on Sep 07, 2009
etcrCustomPC
  • 61 Answers
SOURCE: internet wont connect
Are you using Vista, XP, Linux?
  1. Check the Device Manager
  2. Click Start
  3. Right click My Computer
  4. Select Manage
  5. Click Device Manager
If you see anything with a yellow question mark then you may need to update the driver for it.
If there is nothing missing a driver then we'll move on.
If you're running Vista I have seen 4-5 cases personally where this occurred for no reason and I could not get it to connect to ANY network.
  1. Click on the wireless icon in the system tray
  2. If it say that you are connected but with limited access
  3. or local access only
  4. or no internet
This is the same problem I had people bring in on their laptops, the only thing that I could do was to reinstall Windows, I tried updating drivers but nothing worked.
But first you should try to update the driver, but you'll probably have to reinstall Windows.
Posted on Sep 16, 2009
Backlight & volume fn hotkeys g73jh not working
restart and HOLD the key f2 or esc for enter the BIOS setup, and adjust the hotkey, Enable.
God bless you
Jul 24, 2013 | ASUS G73JHA1 Notebook
I have acer AOD257. before i have a acer crystal eye webcam but it suddenly stop working.everytime i open it says
The oiriginal Acer webcam was providied by the manufacturer as a software program to be used by microsoft! After the warranty expired, I installed windows 7 and the camera disappeared! What does that tell ya!
Nov 01, 2012 | Acer Aspire One D257 Netbook
AC stopped working - only flashes "PF" now.
I found the instructions call 1800 322 3848... My just said the same thing
Sep 10, 2012 | Kenwood PAC C130EK 13000 BTU Portable Room...
My windows key is not working plz help solving it
Try using the "CTRL" key as a modifier (Holding it down) and then press the "ESC" key one time. This should get you by for now. As for the not working Windows key. You could have a number of mechanical failures there. All depends on how the board is put together. You will likely need a new board, but if you find that the "CTRL" + "ESC" key combo doesn't work either, then this could even turn out to be a software issue. You might want to verify that all other keys work on the keyboard. You might find a dead region.
Dec 28, 2010 | Dell Computers & Internet
Dell inspiron 1300, g and h keys suddenly stopped
There are some circuits malfunktion in your keyboard.
Try to connect and external keyboard and you will see that the external keyboard works fine.
This way you can continue using your computer,
and continue writing,untill you get a replacement keyboard.
You need to replace the keyboard.
Hope this helped you to continue using your computer.
If you were helped. Please vote!
May 12, 2010 | Dell Inspiron 1300 Notebook
Cannot wake up my laptop elitebook
Press the power button for some seconds so that your laptop shuts down. Then try to start it again.
Aug 22, 2009 | HP Elitebook 8730w Mobile Notebook
I have set up my compaq computer , it was working fine, then I shut it down. Now when I start it up it goes into the compaq screen asking for press esc or f11 or f10 etc for rebooting etc. What have I...
The Start up screen for Compaq series computers is normal, that screen takes you into your BIOS mode. when the screen appears press F1, at the bottom of the screen it will say press F5 or one of those keys to install your Default Settings, Click Yes and Exit. That should do it. Good Luck.
Oct 28, 2008 | HP Computers & Internet
Key board
the ones on my laptop suddenly stopped aswell. i just kept pressing them down and eventually they started to work again. and fine ever sinse then. hope it helps.
Jun 23, 2008 | HP OmniBook XE3 Notebook
ASUS K40IN Notebook Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
