Question about Car Audio & Video
I have just bought a soundstream pca1000d amp from.my friend but he did not have the remote bass nob so I was wondering where I could get it from
    Master:
  • 689 Answers
The bas control nob is just a grimack end a waste of money,You don,t need it because all the decks in the last 8 years have,Sub level control on them, Where you can adjust the level of bas from the (Deck) All your asking for to happen, Buy all so useing the bas control for the amp, Is to (Blow) Your (Subs) End fry your amp, When you use both of them for controling the bass, You are causeing the sub end the amp to over heat, I installed car audio for over 40 years , before i retired this summer, End seen lots of amps end subs that were damage, Buy guys haveing them hookup all so,End anouther thing that damage subs end amps, When they have the grain control on the amp crank right up.
Posted on Nov 08, 2012
  • Josh carlo Nov 11, 2012
    well people blow up their subs if they dnt knoe how to install / match and use their system but thanks anyway
  • Rob getz Nov 11, 2012
    Why .if your so smart then are you asking where you can get the bass control from no it all?
5 Suggested Answers
  • 108 Answers
SOURCE: need to know average amperes need to run at moderetly loud level
Go by the fuse rating on the amplifier as a default. i.e. - If on amp has a 40 amp fuse on the outside and another has a 30 amp fuse on the outside, then you need to supply at least 70 amps of current. the formula works like this: amps X volts = watts. Doing the math here, for an amp to produce 1000w of power @ your vehicle's 12v power, you need 83 amps of current. Most cars produce 14v from the alternator when running, so this is really only needing 71 amps. Make sure your car's alternator can supply the excess current when running. Most modern amplifiers are efficient enough to produce their wattage with even less current than that.
Posted on Aug 03, 2008
SOURCE: Soundstream rub 500-1 mono....
U need to make sure your subs are wired correctly. And u need to make sure all your speakers are at the same ohm load. If u hook up two subs on one channel and two more on the other one u need to make sure that your subs are all 2ohm or 4ohm subs cause if u got two 4ohm subs ran parrallel then u will have a 2ohm setting and if both of them are 2ohm subs them your load will be a 1ohm load witch could harm your amp unless its an 1ohm stable amplifier.
Posted on Nov 21, 2008
  • 1596 Answers
SOURCE: pheonix gold amp bass remote
i just had the same amp and tried using my buddies bass knob from a different model wouldnt work so i called company they said you have to have the cord that came with the amp
Posted on Jan 29, 2009
SPL Freak
  • 63 Answers
SOURCE: Pyramid PB1500 vs. Metrik Rem. Bass knob????
Yeah it's probably not going to work because it's not even the same brand
Posted on Mar 06, 2010
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
I hooked up a system in my truck had it for a year everything working fine.i listen to music really loud anyways i have my wires hiddin under my back seat well when someone layed the seat down it cut my...
Because even though your stereo is turned down the gain for the sub is set all the way up so it will still gain a small amount of signal. it is a flaw with some of the newer aftermarket stereos. try turning the nob until the thump stops then change the bass setting on your deck to compensate for the bass loss.
Jan 28, 2011 | Car Audio & Video
Sound stream little wonder 62o. keeps tripping off for no reason its new only 3 weeks.spoken with other persons they have the same problem
IN MY OPINION I WOULDNT OWN A SOUNDSTREAM AMP NOT BY ANY MEANS KNOCKIN UR AMP BUT IVE NO GOOD LUCK W ANY SOUNDSTREAM AMP IVE EVER HAD
Feb 19, 2010 | Soundstream Tarantula Car Audio Amplifier
Jan 18, 2010 | Pyramid PB1500 Car Audio Amplifier
Pheonix gold amp bass remote
Jan 14, 2009 | Car Audio & Video
Nov 21, 2008 | Soundstream RUB500-1 Car Audio Amplifier
Need to know average amperes need to run at moderetly loud level
Jul 25, 2008 | Soundstream PCA1000D Car Audio Amplifier
Constast cycling sound from my stereo onlt its intermitent
If the other speakers play after the door speaker wires are disconnected, the problem is likely a speaker wire shorted to the door. If the vehicle had OEM amps and you didn't bypass them, that could also be a problem.
Disconnect the door speaker wires from the amp and check for continuity from the speaker wires to ground. There should be none. Also check the resistance across the speaker wires. They should read approximately the same as the rated impedance of the speakers.
Mar 02, 2008 | Soundstream PCA1000D Car Audio Amplifier
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
