Question about Refrigerators
Thank u for answer but tried that it's not making anything not cold enough Frizzer won't stay at frizzing keeps going up and down but not higher than 30 but even at that no ice at all help if u can d
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Nov 07, 2012
My car wont go in between the hot and cold meter
engine - Car temperature displaying below Cold or just ...
mechanics.stackexchange.com/.../car-temperature-displaying-below-cold...
Jun 25, 2012 - Today I was boiling inside my car as it was a very hot day and my ...cold, it almost never goes up to even 1/4 of the temperature gauge, the ... Where I live, it's hot enough that even with the thermostat wide open the engine won't stay at C.. ... How to Match Skin Color Between Pictures Of The Same Person In ...
What does it mean when my car's temperature gauge is halfway ...
https://answers.yahoo.com/question/index?qid...
Aug 23, 2011 - I think my temperature gauge is usually all the way to the left, which I think is "cold" (okay). ... before steam poured from under the hood of my car and I had to pay $217 ... Why does my A/C stop blowing cold & my temperature gauge goes toHOT? ... But the battery won't keep a charge after sitting over night. my temp gauge always stays on cold. never moves.? ' Yahoo Answers
Mar 28, 2014
My car temperature gauge started going crazy and it doesnt even ...
Nov 10, 2011
My engine temp gauge reads below normal, close to cold, even ...
Mar 23, 2007
my temperature gage on my car keeps going up and down.. does ...
Feb 15, 2007
More results from answers.yahoo.com
Dec 01, 2015 | 2002 Acura RL 3.5
Air Compressor will only pump up to 35lbs.
The two main areas to inspect if your pressure isn't going over 35psi are the valve plate and piston/cylinder assembly. If the reed valves on the valve plate are bent, warped or broken, usually attributable to high heat, they won't seal well enough to get higher pressures. If the cylinder is badly scored or the piston and/or piston rings are damaged, usually attributable to running the pump motor with low or no oil, the seal between them won't be good enough to get the pressure any higher.
Aug 13, 2012 | Craftsman Air Tools & Compressors
2003 Pontiac Grand AM V6 Overheating
You have sir in the system. You have to purge the air outdo that the thermostat can open and coolant can actually circulate through the engine.
Mar 15, 2012 | Pontiac Grand Am Cars & Trucks
Kenmore freezer and refriderator keep shutting down and not staying cold.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 11, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have to set the temp all the way up to get the fridge to come on, but it won't stay on. it will last all day, but goes off during the night.
NOTE: This
Leo Ponder
Sep 08, 2011 | Haier HSB03 Compact Refrigerator
My roper side by side refrigerator has been making a clicking noise inside of the refrigerator. The freezer keeps having ice buildup and the fridge won't stay cold. I've already replaced the...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
Leo Ponder
Aug 11, 2011 | Whirlpool Refrigerators
Iv got the baby blue remington shine therapy hair straighteners but i keep hitting the heat button i try to lower my hand down th straightner but its not very comfy how can i avoid hitting the heat button....
I realize this post is a few years old but I'll answer anyway in case someone else needs help. If you press and hold the - (minus) button it will lock the temp and power button and won't unlock until you press and hold the - button again.
Jul 21, 2011 | Remington S9951 Shine Therapy Frizz...
Frig will not stay cold unless you keep moving the controls back up and then down. but it won't last but a few days and then you would have to do it all over again. i think it may be the thermostat or...
the thermostat is most likely to go. i would replace that. if you want to make sure and you have a meter handy. set it to then ohms scale. turn off the power remove control cover set a test lead on each side of the control knob. as you go higher your resistance number goes higher. then you no its good. to test the thermostat you would have to turn power on. i dont recommend it unless certified, if seen some things. thanks hope this answer helps.
Jun 20, 2011 | Whirlpool (ET8FTEXSQ) Top Freezer...
WE BOUGHT A 25 CUBIC AMANA REFIGERATOR AND WOULD LIKE TO KNOW WHAT TEMPERATURE SHOULD THE REFIGERATOR BE AT. OURS WAS SET AT 4 BY THE INSTALLER, BUT I HAVE NOTICED THAT OUR MILK IS SPOILING BEFORE THE...
Depending on which is the lower temp settting I would say you are correct I would set it to a higher no.Assuming the higher no.is a colder setting and not vice versa try 5 for a day or so and test the milk by drinking it and see if it is much colder but not freezing.if npot cold enough go to 6
Mar 07, 2010 | Refrigerators
Frizzer frizzes completely including the walls. then not enough cool air come to the fridge. so the fridge gets warm. My food goes bad.Then the wall star getting unfrozen. help.!The drainish hole also gets...
try cleaning the bottom of fridge of lint and dust,, can cause alot of problems,,may sure you clean the coils at the back bottom of frige,,see if that help,, if not gas not right
Aug 11, 2009 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
