Question about Dryers
My kenmore 800 series dryer gets way to hot, why is that? how do I test the thermostat/ thermister?
When turned on, the heating coil gets way to hot, like red hot, like a toaster oven. im thinking thermostat, thermal fuse? how do I test? please help!
    Problem Solver:
  • 18 Answers
You may have lint build up somewhere I side the dryer. You may need to open up the dryer and clean out the old lint.
Posted on Nov 09, 2012
Heat cuts out shortly after dryer starts. Have taken apart several times. First replaced thermal cut off (tested bad) and thermostat. Element ok. Good airflow. Dryer seems to heat up very quickly and very...
Sure can!
Most Kenmore style dryers have a heating element that has a long wire coil inside it, (often there are two wires or elements inside one housing). Regardless, if you have carefully checked the air exhaust, and you find it is "perfect" ( means no back-up heat from a plugged or impeded air flow) and you have determined the air flow inside the machine is like new, ( no back up there either), then what has possible happened is the wire heating element has wiggled loose and is touching itself, thereby shorting out and making super heat.
The wire coils are usually held loosely in place with white ceramic rings, to keep them from touching the metal housing. If you carefully remove the heating element "box or "tube" and look inside , you may be able to see the problem. Testing it with an ohm meter will not work, it will simply test OK. The element is made to heat at a certain temperature according to it's length, if it touches itself, the elecrttricity will take the shortest route and may make your element glow white hot in one spot. Be blessed.
Sep 02, 2013 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore #11066742500 dryer
Could be several things. If it is a new hookup the neutral and one of the hot wires has been reversed. If it just started doing this the most probable is a shorted heating element. It will still test good on continuity test but part of it is touching the frame. The third thing is a bad thermostat, it would be cycling at too low a temperature. The temperature coming out of the exhaust should be between 150 and 175 at high heat.
Jan 21, 2012 | Dryers
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
Electric dryer only heats occastionally
Could be a circuit breaker getting hot an opening on the heat load side
or it might be a faulty control thermostat or thermisterf1ba79e.jpge295fb2.jpg60438dd.jpg
May 08, 2010 | Kenmore 62882 Electric Dryer
I have a kenmore 400 series dryer model no heat
Srart by pulling each thermostat wires and tape them together until you find the bad one. You should have 3 of them to test.
Oct 25, 2009 | Kenmore Dryers
Hello. I have a Kenmore series 80 dryer approx 7
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Oct 19, 2009 | Kenmore Dryers
Kenmore dryer does not heat
I have a kenmore series 80. Had the same problem...the fix was replacing the gas coils. The dryer would get hot for about 10-15min then nothing. The gas would stop firing but you could see the igniter glow over and over again. Hope this helps.
Apr 02, 2009 | Kenmore Dryers
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Hello My Kenmore 84152 dryer stopped making heat. I have varified the 2 thermo units each read 0 ohms the lower thermister on the blower houseing read 89.4k ohms and I can't for the life of me get to the...
AS LONG AS YOU GET READING THE IS GOOD ,NO READING AND THE PART IS BAD,TRY TO GET ONE OF THE TERMINAL OFF THE HEATER COIL AND YOU STILL CAN TEST IT THAT WAY,MORE THEN LIKEY IT IS THE HEAT ELEMENT BECAUSE EVERTHING TEST GOOD RIGHT?HOPR THIS HELPS,THANKS-MIKE
May 30, 2008 | Kenmore Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
