No closed caption on sharp lcc4067un
Cable system is comcast
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Both the set and the cable (if box used) should have this feature--look in menus for each to engage it---some it can only work with sound muted or all the time etc depending on what you select.
Posted on Nov 08, 2012
circuitcity
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Posted on Dec 09, 2007
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
SOURCE: toshiba 62hx94 cant shut off closed caption have comcast cable
The problem was with the Motorfolla Comcast cable box not my T.V. . I turned off my Comcast cable box, pressed menu on the remote to the cable box. This made a 16:9 ratio appear on the cable box's LED read out, and a bluish screen appear on my television. One of the options on my television was to turn on and off closed captioning. Therfore, I turned off closed captioning and the problem was solved.
Posted on Jan 30, 2009
SOURCE: Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Posted on Mar 17, 2009
  • 16 Answers
SOURCE: How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Posted on Apr 02, 2009
On set-up menu the closed caption option is not highlighted to engage closed captions.
are you using the original remote control of the tv? did you try the remote control provided by comcast? go to comcast website for further help.
Oct 04, 2015 | Televison & Video
We have a Sharp 25J-M100 and we cannot turn off the Closed Caption. We hit menu on our Sharp Remote Control and go down to Closed Caption and make sure it is off. The words never go off of the screen. Our...
If the captions are turned off on your TV, they have to be coming from your cable box. The TV is just displaying what it's getting. Check your cable box menu and make sure captions are turned off there. Cable boxes, especially on digital systems, can prevent the TV's caption decoder from operating properly. So they need to be able to provide captioning, and I suspect you've turned it on somehow. Comcast should be able to tell you how to turn off captions if you can't figure out the menus.
Jul 15, 2011 | Televison & Video
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba 62hx94 cant shut off closed caption have comcast cable How do I turn off closed caption on my TV. It suddenly turned on. can' turn off closed captioning 20" ws
Jan 30, 2009 | Televison & Video
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
This is what just worked for me. If I can figure this out, anyone can :) We have comcast cable hddvr box, motorola 3416, and a new Samsung HD Plasma, but try this no matter what you have...
turn your cable box off, and THEN press menu on the box. A white screen popped up and this is where I had to scroll down to and disable the captions. I couldn't believe this worked since I thought the cables were enabled on my TV since my captions were covering my cable menus, but it was the cable. I hope this helps.
Oct 23, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
