Question about K2 Cycling
Freewheel fails intermittently - K2 Cycling
  • 843 Answers
I assume you means that it slips sometimes. This is usually due to the ratchet mechanism just needing a bit of lube. If you have a thread-on type freewheel (see image below) then you can usually just squirt some WD40 into the little holes near the center of the freewheel. Those holes would be facing the table in the threaded freewheel pictured below. If that doesn't work for you, it's not all that difficult or expensive to just replace the whole freewheel. However, if you have the splined type pictured on the right, the ratchet mechanism is in the wheel's hub, making replacement more of a big deal. WD-40 would probably do the trick on this type too, but I never had one some I'm not certain how easy it is to get the lube where you need it. Good luck!freewheel fails - 11_8_2012_3_08_02_pm.jpg
Posted on Nov 08, 2012
Testimonial: "To Al Kupchella..........YES, YES, YES! And thank you, thank you so much. Although I can't tell if I have a threaded or splinned cluster, I was liberal with the WD-40 and your solution worked. Much appretiated.....Bob "
Beep code 5 keeps going off, the manual freewheel lever is in the drive position. Can I repair it?
Hi remove the key for a short while make sure freewheel lever is in drive & replace key & try it out. If this doesn't help take key out put freewheel lever In freewheel then put it in drive put key back & try again good luck
Apr 13, 2014 | Pride Mobility Products Go-Go Elite...
Freewheel not locking in
The pawls (small spring activated plates) inside the freewheel body are stuck down and cannot spring back up to engage the gear body.
This is usually caused by oxidation and moisture.
This is a long term issue, the freewheel really should be replaced. It may randomly work if you can get a lubricant to penetrate into body, but this is normally a short term solution.
Most freewheels from Sram or Sunrace will run about $20.00.
Dec 26, 2012 | Mongoose Mens Xr250 Bicycle Grey 18-Inch
Serpentine noise
the clutch and bearing assembly is failing it is a freewheeling pulley till clutch is engaged but it has bearings which can fail
May 09, 2017 | 1996 Plymouth Grand Voyager
My son's Schwinn Ranger is the problem. the back wheel and the back sprockets are "freewheeling". When you pedal the sprockets spin but are not connected to the hub, you can pedal forwards...
ok well its best decided how to fix it if you can tell me what style of rim and freewheel you have if the freewheel goes all the way to the tip of the axle then its more than likely a cassette style rim and if it appears hollow at the axle end and you can somewhat see inside the freewheel then i would just buy a freewheel cassette for it because in most cases a faulty freewhell body cant be serviced and need replaced when they fail up on you another cause of this is riding in the winter so find out what kind it is and message me back ok ill better inform you of the best possible way to ride happier longer :) this is also a super common problem ok
May 10, 2011 | Schwinn Cycling
Rear sprocket does not engage when pedaling
It sounds like the freewheel mechanism within the rear hub has failed. When freewheeling does the hub click at all? If not, you will require a new rear wheel.
Feb 28, 2011 | Mongoose Cycling
Im try get a freewheel removel tool for a mens 26 in. magna glacier point, what one do I need
If you can determine what brand and style of freewheel/cassette it is, this company makes the tool for it. A local bike shop would be able to do it for you if you bought the freewheel from them, I imagine.
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Feb 22, 2011 | Magna Cycling
How do you take coggs off back wheel of my bicycle
If one wants to take off the whole freewheel, one usually buys a freewheel removal tool that matches the brand of freewheel, takes off the wheel, takes out the quick release skewer, puts the removal tool onto the freewheel, uses the quick release skewer (lightly screwed on) to keep the tool from slipping off, then clamps the removal tool into a well-mounted vice and unscrews the freewheel by grasping the wheel rim. They usually come off before something breaks... but occasionally not if they've been on for a long time, since pedaling tightens them... and tightens them... ;-)
- Roy
Oct 10, 2009 | Falcon Mountain Bike Maintenance
10 speed roadmaster
Sounds like your freewheel is a little too free. First off, I'd recommend replacing the rear sprocket, or freewheel/gear cluster. If you DO get it working again, there's no guarantee it'll work well enough to not skip when you're pedaling hard. Ever had a freewheel fail or a chain break when you're really honking on the pedals? It ain't pretty.
That said, it could be the ratcheting mechanism is gunked up with old grease--try squirting some WD40 or other light lube into the guts of the thing and tap it lightly (!) on the side with a wrench or hammer to loosen up the pawls. Better would be to remove the freewheel and soak it in solvent to loosen it up, then re-lube it. To do THAT, though, you'll need a freewheel tool to pull the rear cluster off. If you have the tool, great. If not, time for a trip to the bike shop, and you're best off getting the freewheel replaced.
If there aren't too many miles on the drivetrain, you might get away with having a bike shop replace that rear cluster. If it's old and worn, you might end up having to replace the chainwheels (front sprockets) and the chain, too. I know, what a pain, but as these parts wear into each other, they can skip around when only one part of the drivetrain is replaced. One step at a time, though, and good luck.
Jun 08, 2009 | Cycling
Cycling Logo
132 people viewed this question
Top K2 Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a K2 Cycling Expert? Answer questions, earn points and help others
