Sometimes the ribbon cable underneath the scanner can bind the scanner if the adhasive has come loose. If you can remove the scanner glass, the ribbon cable can be secured with some scotch tape.
turn the power off remove catridge then check there is not any paper jam also check in back side.
then if problem remains then open the front chip bord in centre pull it then refix ram after clean dust from its.also reset your printer settings to factory defauts
what does the pyramid red lights on the main pannel means. Is it because it needs toner or it needs...
(More)
what does the pyramid red lights on the main pannel means. Is it because it needs toner or it needs a new drum?
I just added the new ink cartridge and the light for the addd new drum cartridge won't go off. what...
(More)
I just added the new ink cartridge and the light for the addd new drum cartridge won't go off. what do i do?
guys have you ever seen a Sharp AL 1651 with a small case letter 'd' in the display? this happens...
(More)
guys have you ever seen a Sharp AL 1651 with a small case letter 'd' in the display? this happens when the machine is turned on in the morning....several on/off cycles will clear it. When it has the 'd' it is locked up...can't get in the service mode or anything...very strange. Any ideas?
Scanner clicks, looks like belts are slipping. It says to refer to user guide but there is no such...
(More)
Scanner clicks, looks like belts are slipping. It says to refer to user guide but there is no such error code in the book.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
