Question about Dryers
Top of Dryer getting scalding hot
I have a Frigidaire (model #FER211FS), we bought brand new 4 years ago. The dryer worked fine at the old house, we just moved and the top right hand side of the dryer is getting burning hot (you cant even touch it). I opened up the lid and that is where all the wires are and there was a burning smell. Is it time I need to get a new dryer or is this fixable without spending a ton of money?
  • kjablonski Jan 05, 2009
    Thank you Tom!! I am calling the apartment maintenance to see if they can come and check the duct work to see if there is a clog. I pray this is the problem. Thanks
    Sergeant:
  • 311 Answers
Hi there try drying a load without your house ducting.if its restricted at all this cause the heat to not leave the dryer a designed by manufacture and their for get hotter.can be other things but thats most common.ps should have good air flow leaving dryer when vent off.but because fine at house just moved from i think new house is the problem.God bless ,tom
Posted on Jan 05, 2009
  • 1 more comment
  • Thomas Malailua
    Thomas Malailua Jan 05, 2009
    yes but they also will try to clean or say its clean[ive see those guys say that lots of times]and its not ,but see what happens.if stiil not good try my advice to dry with no vent,[it wont hurt a think] God bless ,tom
  • Thomas Malailua
    also please dont forget to help with my rateings. thanks,tom
  • Thomas Malailua
    Thomas Malailua Jan 06, 2009
    if i have been helpful please remember to help with my ratings
The dryer does get hot but takes a very long time to dry a normal load of clothes. What I noticed is that the top right hand corner of the dryer gets scalding hot during the cycle. It worked fine before I...
It sound like you have a venting problem. The air from the dryer is probably restricted by either a clogged exhaust hose or duct work in house or a stuck vent flap where air blows to the outside. If your vent goes straight up to the roof, something may be blocking the exit or the whole line may be clogged. Also check for a kinked flex hose that attaches to the dryer. If blockage is in wall of house, there are vent cleaning companies that can clean out the line.
Feb 04, 2010 | Kenmore 84052 Dryer
No power is there a fuse in the dryer. The power is ok. Could it be the plug? It is at my summer home it is a stackable purchased about 3 years ago. I don't have the model. It was purchased at Lowes
There is a fuse in the dryer, its called a high limit sensor. If the dryer gets too hot the high limit blows like a fuse and saves your house.
Make double sure you have proper power at the outlet before you tear into the machine.
Good Luck
Quentin
Oct 05, 2009 | Frigidaire FEX831CS Top Load Stacked...
I bought a used dryer (model # fde336res2, serial # xd01501804)The dryer works, needs a knob but it also eats my clothes. It seems to be a problem between the barrel and the front panel. The clothes get...
Your problem could be caused by a bad felt seal..the drum rotates against this seal. The purpose of the seal is to seal the hot air from going out of the drum and into the room.
Remove the front of the dryer and this should expose the drum and felt seal.
Sep 25, 2009 | Frigidaire Dryers
How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer gets hot and shuts off after five minutes,
Check your vent tube to make sure it is clear. It is probably getting to hot because there is no ventilation to the outside. When you have the front off, check all the way from the lint filter to the outsid of the house.
Mar 23, 2009 | Frigidaire FEQ332E Electric Dryer
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryers Logo
134 people viewed this question
Top Dryers Experts
