Question about Zenith Televison & Video
The scrolling banners on the top and bottom of my zenith monitor are cut off. according to my manual, it is 1 of 6 models: SR2573, SR2783, SR2739, SR2773, SR3238, SR3273.
The scrolling banners at the bottom and top of my monitor screen are cut off
    Top Expert:
  • Zenith Master
  • 14,553 Answers
Either an adjustment of the vertical height or Lin or a circuit problem in the vertical circuit.
Some sets have physical controls inside the set on the board or in a hidden menu via the remote.
Posted on Nov 08, 2012
  • 192 Answers
SOURCE: Picture partially cropped at bottom of screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Posted on Dec 24, 2007
techman
  • 3130 Answers
SOURCE: Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Posted on Sep 12, 2006
techman
  • 3130 Answers
SOURCE: picture is cut off on top and bottom
Thats is not going to fix your problem. You have a bad vertical output IC and or a bad capacitor in the vertical drive or output circuit. Good Luck
Posted on Mar 31, 2007
  • 20 Answers
SOURCE: horizontal screen size
will probably have to take to service center. will need to get into service menu and nedd serive diagram.
Posted on Mar 17, 2008
rsheehan
  • 69 Answers
SOURCE: Phillips flat screen 27 inch screen cuts off top and bottom
horizontal over scan , one H.V. cap is out of tolerance in hoz deflection
Fair Cost to fix 75.00 could be a few leaky diodes to. in addition to the cap
Posted on Jul 01, 2009
Picture Size
please provide the maker & the model & part # of your unit..
Thank you
May 02, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
How do I change the number of rings before it goes to voice mail
The manual is available from:
http://www.manualslib.com/download/678020/Vtech-Cs6859.html
( be sure to ignore the advertising large button
"start download" and use the smaller button "download"
across the top banner "downloads" "table of contents" etc. )
then enter the security-codes & click "Get Manual"
then click 'Download pdf'' etc. )
The directions to set the number of rings for the
Answering System are on page 51.
To summarize Setting the Number of Rings:
1. press [MENU]
2. scroll up/down to "Ans System" then press [select]
3. scroll up/down to "Ans System Setup" then press [select]
4. scroll up/down to "# of Rings" then press [select]
5. scroll through the choices, at desired one press [select]
6. press [off ] to conclude & exit
May 05, 2016 | Vtech CS6859 Cordless Answering System...
Formatting tv screen
Check its aspect ratio. Refer its user manual for these details.
http://google.com/+GopakumarGopalan
Jan 01, 2014 | Coby LEDTV1926 19 in. TV
How do I remove the video banner on the wega kdf-42we655 screen
The info banner of your HDTV is turned on. To remove or turn it off, just simply follow these steps.
1. Press Menu (on remote commander)
2. Press UP or DOWN arrow button to highlight the SETUP icon and press ENTER
3. Use Down arrow button to scroll down through the Info Banner.
4.Press Enter to select this feature.
5.Use arrow buttons to scroll through options on or off .
6.Select off and press enter button to disable the info banner.
7.Press menu to exit.
Oct 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Top and bottom of the picture is cut off.
look for a button on the remote control that says, "pic size"," zoom","aspect" and scroll through until you get to 16x9, full , fill screen . i can't remember what this model states on the screen.
Feb 19, 2009 | LG 42PC3D 42 in. Plasma Television
Image goes off screen
it requires a TV repair person to fix the internal problems.
Jul 08, 2008 | Zenith C27A24T 27" TV
Hot key
for mine it's:
tap scroll lock twice then press 1 or 2
Sep 26, 2007 | Belkin F1DK102P 2-port KVM Switch
Tv won't get channels
We have the owners manual in case you misplaced yours . All ya gotta doi to get it is to click on the zenith B32A34Z model # At the top of this page and scroll down to the manual. Now according to the manual in the menu there is an antenns /cable setting and its in the EZ progrom mode. look at the manual as I dont remeber 100% but its there. It sounds like you or someone switched it when they were in the menu. Good Luck
May 11, 2006 | Zenith B32A34Z 32" TV
Televison & Video Logo
52 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
