Question about Lexmark T640 Laser Printer
Print from both trays
A user wants to print Letter size from both trays, so if the first tray runs out of paper the second will be used. We've tried a few things (which obviously did not work), and the minute we remove the tray the paper has been pulling from we get an error. This is a Lexmark T640 printer. Any idea? Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
Not sure with a that Model, but on HP lasers, you just tell the printer that the trays both have the same paper in - i.e. Plain Letter. When one runs out, the other takes over.
If the printer thinks one tray is Plain and one is i.e. Bond paper, it won't switch trays even if the same physical paper is in there.
Go through the control panel on the front of the printer, or if it doesn't have one, you'll need to use the web interface to set this up.
Posted on Feb 10, 2009
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Print jobs stick in prnt queue
A lot of users have no idea how to change the MS Office default from US to UK .. so they have US spellings and US paper sizes (known as 'Letter' sized) .. and (of course) any Document that started life in USA keeps it's size until some-one changes it ... since Letter size is almost the same as A4 no-one cares UNTIL they come to print it ...
I'm sure you can guess the rest :-)
Yes, the Printer is looking in it's feed tray for Letter sized paper .. yes, Letter doc's will print just fine on A4 and most printers have a setting somewhere that lets it use A4 when asked for Letter (often called "automatic A4<>Letter convert" or some such)
NB. when time permits, perhaps the unfortunate users can have their MS Office apps. set to UK mode :-)
Mar 17, 2009 | Dell Office Equipment & Supplies
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
3055 sends to manual feed
Hi there
I've had a similar problem in windows instead of the mac, but it sounds like it's a
similar problem where the computer's telling the printer to use a
different sized paper to what the printer's been told is in the trays. For example, if, say, your document is set up for A4 sized paper, but the printer is set up to think it has Letter sized paper in the trays, it'll ask to have A4 sized paper installed in the tray instead.
Go into the system setup on the printer and select the paper setup menu.
Select Tray 1 and choose the right paper type and size from the settings (After you choose the paper type you have to go all the way back through the menus on the printer and choose the paper size as well)
Hope this helps!
Nov 22, 2007 | HP LaserJet 3055 All-In-One Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Lexmark T640 Laser Printer Logo
252 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
