Question about RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01)
Converter box turns off every 15-45min
My new digital converter box turns its self off every 15 to 45 min.
  • Daniel Ide Oct 12, 2012
    turn off sleep timer on tv and box
    Genius:
  • 1,913 Answers
Reset it to factory defaults settings.press reset switch or power bur\tton for 10 seconds.
a
Posted on Jan 05, 2009
Ineed a code for tv converter box,What would the code be for a tv converter box ?
Different brand converter box will have differen tset-up codes. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jan 11, 2017 | Televison & Video
While watching tv, we lost sound. We thought it was the tv but when we use the wii or netflix through the wii, we have sound. We are using a Zenith tv digital converter as well as have things routed...
Reboot the digital converter box by unplug,replug it back like 10-20 mins later.If u still getting the same problems no sound,tries by checking out the RCA cable connections,tries take out the red wire and check for damages and plug it back in or tries changes another RCA cable set all to gether.After new set of RCA cable should be working 100,if not the digital converter box is the problems,than now must change the digital converter box,this box no longer on sale by those big box stores.If u require to change the digital converter box tries websites like Amazon.com,Ebay.com to buy those converter boxes.
Feb 17, 2011 | Televison & Video
Where is the cadalytic converter located on a 1994 chrysler lebaron?
The catalytic converter on your Lebaron is the section of pipe attached to the exhaust manifold. The converter its self is running at about a 45 degree angle up to the engine.
Aug 28, 2010 | 1994 Chrysler LeBaron
Have a converter box. Had to change battery in remote and now tv will not turn off.Have a rca tv
hold the power on off button down and press the channel up button repeatedly up to 45 times until the tv set turns off.
Dec 11, 2009 | Insignia Digital-to-Analog Converter for...
I have hooked up my converter box but its not receiving any signal. do i need to buy a new antana? Or what could be the problem?
make sure u have the antena hooked to box and box hooked to tv, make sure antena wire is actually hooked to an antena if wire is coming out of the wall, otherwise u more than likely need a new antena, or box it's self is bad but if it turns on and u see somtin on the screen like make sure antena is hooked up then the box is probaly good
Nov 18, 2009 | Insignia Digital-to-Analog Converter for...
Since the switch to digital transmission, my antenna no longer works with my Trutech 19 inch TV. What kind of antenna do I need to buy in order to get reception?
to add to what MIKEY-MOORE wrote, OUR government was offering discount ($20 off a $40-$45) coupons on a digital converter box that you can use your original antenna ( I still use my original nineteen and 65 (1965) rabbit ears antenna) to receive the digital signals NOW being transmitted through the air. In order to receive the signals YOU MUST get the converter. GOTO any Radio Shack, Walmart, to acquire the converter box. You will need one for EVERY tv in your house. I have a HDTV (but not digital) and I had to buy 3 boxes.
Jul 17, 2009 | TruTech PM1919BXA1 19 in. LCD TV
Do I need to get a digital converter box for the new dtv?
If you don't use an outdoor antenna then no, you don't need a converter box.
However some channels have to go through a rented digital cable box from your provider for some channels to be recieved.
Jun 01, 2009 | Televison & Video
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01) Logo
589 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
