Question about Casio Exilim EXZ75 Digital Camera
Need to config each time i turn on - Casio Exilim EXZ75 Digital Camera
I have a stairmaster 4400 and every time I get on and try to select a workout it says config rqrd and if I push the clear button it turns off
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Feb 26, 2014 | Stairmaster 4400 PT Stair Stepper
Corrective Action
Every time I get on it says config rqrd and it won't let me select any workout it just turns off
Corrective Action
Stairmaster 4600 Cl Freeclimber CONFIG RQRD on display none of the codes on this forum worked. I will first get on my machine and for one sec CONFIG REQRD will pop up then go away, it will the ask me to...
Corrective Action
Just a tip, I suggest hitting the clear button about 2-3 times before entering Level up 80. Follow the procedure from there.
Jan 14, 2012 | Stairmaster 4600 Cl Cordless Freeclimber
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
My email account has been locked in yahoo. How can I unlock this?
What you need to do is try signing in from a different "server". Basically if you try to sign in incorrectly too many times on one of yahoo's sites they will lock your account, but only on that server.
Here is a list of yahoo email servers. Try a different server.
  • http://cn.mail.yahoo.com/?id=77070
  • http://edit.india.yahoo.com/config/mail?.intl=in
  • http://edit.europe.yahoo.com/config/mail?.intl=uk
  • http://login.yahoo.com/config/mail?.intl=cf
  • http://my.yahoo.co.jp/
  • http://login.yahoo.com/config/login
Feb 28, 2011 | Yahoo Messenger
The screen says configuration required, i had this problem twice before but forgot the code. i only remember up arrow 80. Does anybody know this code?
I provoked that on my machine by turning on "clinical mode". It was OK after turning it off again: ^, 3, enter, then select your way to clinical mode, enter, turn it off, enter.
Sep 28, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
I brought a Laptop (acer) I need to connect to my network but I can't remember my password. How can it get into the router to see what it is. I've called Linksys but they want to charge me 29.99
there a reset button on the back to reset config. so you must have all the router config backup on paper.
to reset router:
1st the router manual, needed for config.
2nd backup router config.(on paper)
3rd press the reset button more than 5 sec. until all lights were off (except on)
4rd reed manual the steps for 1st time config.
then config router again, and test internet connectivity and wireless security level (WPA2), change all router passw every 30days or less.
Dec 26, 2009 | Linksys Wireless-N WRT150N Router
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Casio Exilim EXZ75 Digital Camera Logo
29 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
