Question about Dryers
Heater in bath fan will not work
I would like to know how to troubleshoot the heater, the fan works on vent only and the light works but not the heater
  • Joe Streett Nov 08, 2012
    I checked the element it was okay. I now think it may be the switch because it uses the same fan for heating and venting and when I turn switch to vent the fan comes on but not when I turn the switch to heat.
  • 1,238 Answers
You possibly have heating element problem
Posted on Nov 08, 2012
2 Suggested Answers
bargainbin2
  • 123 Answers
SOURCE: Older Nutone bath- fan/light/heater Model
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Posted on Aug 29, 2009
Will Defiant 49816 timer control the fan? any other timers?
Yes, it will control small inductive motor load like bath fan... but not heavier load like bath heater
For bath heater, and spa controls, use mechanical 1 Hp delay timer.
Ratings and manuals on following link
http://waterheatertimer.org/Countdown-timer-horsepower-ratings#cooper
Self help water heaters timers electrical plumbing
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 06, 2016 | Hardware & Accessories
Jacuzzi tankless water heater code 12 appears
For my Jacuzzi tankless water heater model #J-SN180F: It turned out to be an exhaust issue. If I take off the exhaust vent completely then the talks heater works with 3 baths at full hot water. I get the error code 12 again as soon as I put event an elbow of the vent. So my conclusion is I need some sort of straight vent.
Apr 22, 2013 | Water Heaters
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
Jul 24, 2010 | Broan-NuTone QT100L Fan
Hot water heater not venting properly.
Hi .. it appears that your house is very tight. From your description of leaving a window open , it seems that the gas heater is suffering from lack of make - up air. Forcing the gas exhaust up the chimney will not really resolve this. You will still be trying to move air out without any air input to replace it. You may be able to install a spring loaded vent so there will be an air exchange. Something like a dryer or bath vent hood installed backwards .. this might work. There does not need to be much of a make-up air supply .. something like a 1 inch hole might be enough. I have seen this problem in a neighbors house , he weather proofed his house so good, that his fireplace would not light, no draft !
Any thoughts, concerns?
Please Vote !
May 30, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Older Nutone bath- fan/light/heater Model #9111. Light works, fan and heater do not. Must I replace the entire unit.
Aug 28, 2009 | Broan-NuTone (8663RP) Ceiling Fan
I have an old nutone 656 bath fan and I need to reinstall it and it has 4 wires I need to know how to hook it up
It should be black, white, red and green. Black and white are your hot and neutral legs, green is your ground, and red is your heat leg, heat and light should be controlled on seperate switches, both 110 i believe
Aug 04, 2009 | Broan-NuTone Broan Heater/Light, Model 656
Ihave a new water heater.Worked for 3 days.Now back to Ice baths
All new tank-type gas water heaters for the home are designed with Flammable Vapor Ignition Resistant systems. It sounds like the unit has shut down because of a venting problem. If it is a Rheem or Ruud (General Electric for Home Depot) you have to reploace the heater. Other brands alow for resetting this safety device. Don't take chances with gas if you are not absolutely sure of what you are doing - have a professional licensed plumber check out the problem.
Jun 04, 2009 | Water Heaters
Rheem 40 gal power vent gas water heater shows code 42
you plugged it in and the fan started or you unplugged it and the fan started,,the fan will come on first before the unit will inginte to take out the excess gas, if it didn't lite then the ignitor might not be working there are 2 swithces on the unit one on the fan and one by the gas valve make sure they are both on and make sure the gas it also turned on.
May 30, 2009 | Water Heaters
Dryers Logo
154 people viewed this question
Top Dryers Experts
