Question about LG Washing Machines
Wft857 lg washing machine top load comes up f
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
SOURCE: I have a Whirlpool coin operated top load washing
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
  • 1531 Answers
SOURCE: Rusting lid on top-loading Kenmore Washing Machine
that is very possible.the best thing to do is replace the lid or sand all the rust off and you some rust inhibitive paint to helpslow or stop the rusting proccess.
Posted on Jan 23, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
Lg top load washer 1 year old, vibrates violently during spin. Checked an adjusted level, no help.
they have springs and shock absorbers in the machine to help stabilize the load when spinning. since the washer is so new, i would guess one or the other has just come loose. take top off and check. online videos will show you how
Feb 24, 2016 | LG WT4801CW Top Load Washers
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
Ii have a LG WFT9250PP Fuzzy Logic top loader washing machine. I keep getting dirty ****-like marks on my washing.
Run a hot wash with a Descaler which is available form most hardware stores.Marks on washing usually comes from a build up of detergent and softner between drums.
Oct 15, 2011 | LG WFT1071TP Top Load Washer
Good morning. My top loader is throwing out an
UE means an unbalanced load has been sensed three times, and you must re-adjust your load in the machine. Check out this LG site: http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
If this doesn't help, you may need to replace the Load Balance sensor. Try moving the drum around, back and forth, and see if the problem comes back while washing a small load of clothes.
Feb 28, 2011 | LG WFT1071TP Top Load Washer
My lg WF-T552TH washing machine will not drain the water during a cycle just wondering how i can fix it??
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 25, 2010 | LG WFT1071TP Top Load Washer
I have LG WFT70A37ECT top loading washing machin. getting dE error even though door is close, what is the other reason
How many years is yoru washing machine? I suspect bthe magnet on the lid of the washer has probabkly come off which causes the washer not to identify that the door is closed. U need to replace a magnet on the lid.
Oct 17, 2010 | LG WM-1480FHD Front Load Washer
Moved washing machine and now it won't run
Sounds like a connection may have come loose in the move.
The top cover comes off fairly easily with the removal of some screws in the back. Once screws are removed, slide top cover toward back of washer and take a peek inside looking for loose/disconnected wires.
May 24, 2009 | LG WM2487H Front Load Washer
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
24 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
