Question about Cell Phones
Retroproyector sony modelo kp-53v45 no responde comando de convergencia
  • patricio coronado Nov 30, 2012
    le remplace los stk mas los capasitores el azul y el verde se salen de su linia en la parte superior y en la inferior pongo autosetap y no responde al igual que la cruz de convergencia aparese bien pero no logro mover el azul y el rojo el blanco de la cruz no es total mente blanco aparese medio verde ayuda por favor
Bajanguru
  • 7752 Answers
SOURCE: sony ericsson w800
have the phone model reflash
Posted on Jun 08, 2008
ladywinn
  • 5138 Answers
SOURCE: Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Posted on Dec 03, 2008
ardmax
  • 155 Answers
SOURCE: el lcd prende pero, queda como bloqueado, no me
Me parece que hay un boton que se quedo atorado y que no deja aceptar otras funciones. Por favor de verificar en el televisor si todos los botones de audio, channel, etc.. son libres.
Saludos
Posted on Mar 13, 2011
norsewarrior
  • 57 Answers
SOURCE: I want to buy a PS3 and I have a sony kp-53V45
As long as you have the RED YELLOW WHITE connectors on the back for input, then you will be just fine to connect your PS3 to it.
Posted on Aug 31, 2011
SOURCE: sony de 65" con la convergencia distorcionada
cuando prendo la tv ..se ve bien por unos segundos despues el color verde desaparece
Posted on Jun 24, 2012
Como saber el modelo de mi laptop toshiba
English Translation:
Greetings: I have a satellite laptop and I am trying to check the sticker where it leaves the model and serial number but not visualize anything, but through it I got the serial number through command and has thrown me sgte result 1C157182Q and I get the exact model and to find the drivers for the laptop ...
Toshiba Laptops have the serial and model information on the bottom of the laptop. IF you do not see it on the bottom you will have to remove the panels on the bottom as sometimes they put this information on the inside of the panels.
Hope this helps.
-FlukeLSX
Portatiles Toshiba tienen la informacion de serie y modelo en la parte inferior de la portatil. SI usted no lo ve en la parte inferior, tendra que quitar los paneles en la parte inferior ya que a veces ponen esta informacion en el interior de los paneles.
Espero que esto ayude.
-FlukeLSX
Sep 25, 2013 | Toshiba Computers & Internet
Sony de 65" con la convergencia distorcionada
Nov 12, 2011 | Sony KP-65WS500 65" Rear Projection...
Have a mod # kp-53v45 tv and it wont let me program it to get my cable to run through it, and dont have a manual to it, what to do?
Please open the manual of the KP-53V45 TV by clicking here. To program the channels in the TV, make sure that the cable is connected to the TV using the Coaxial VHF-UHF cable. Select the Auto Program option to program the channels in the TV. Press the MENU button select SETUP MENU and then select AUTO PROGRAM option to scan all the channels in the TV.
Thanks for contacting FixYa.
Jul 16, 2011 | Sony KP-53V45 53" Rear Projection...
Proyector de video imagen distorcionada y poca calidad en la imagen
N?mero y marca de f?brica de modelo de la necesidad. el problema es probablemente circuito de la convergencia.
Jan 18, 2011 | Televison & Video
Tengo imagen negativa kp/51hw40
Hola!
Pruebe los siguientes pasos para resolver el problema: Asegúrese de que las conexiones de los dispositivos son firmes y seguros. Trate de encender y apagar la opción de Digital Reality Creation en el televisor. Trate de ajustar la nitidez de imagen y ajustes del modo de la TV. Presione el botón FLASH FOCUS en el panel frontal del televisor. Esto modifica la convergencia. Si el problema persiste, pruebe a quitar el televisor de la pared a dejar y conectarlo a una toma de corriente directa sin ningún tipo de protector después de 1 minuto. Pruebe a pulsar el botón RESET en el tiempo remoto en el menú de vídeo y compruebe si funciona. Si el problema persiste, el servicio puede ser requerido.
Gracias por usar FixYa.
Dec 02, 2010 | Sony Televison & Video
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Colores
El chassis de synch, no esta funcionando adecuadamente. Probablemente loose connections around.Si puedes quitar el tunner board y resoldarlo, hazlo; Pero la solucion esta en el chassis donde esta el tuner. Tambien lleva unos panel conectado verticalmenet, esos hacen mucho falsos. resoldalos. Por ahi si tienes dudas escribeme noetvs@embarqmail.com Hechale ganas!!!
Jul 29, 2008 | Sony KP-46S25 TV
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
