Question about Mitsubishi WS-65819 TV
The projected image is larger than the screen
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Based on the model number first thing to do is with original remote look for a aspect button.
Also look to see if set does this with tuner and any rear inputs as well.
Posted on Nov 08, 2012
Projection image
your convergence ic's need replacing
Jun 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Creen splits into 2 images
Well I think that you need the av cables for it to work on a digital tv not the rf switch.
Jan 27, 2010 | Nintendo Super NES Console
Image problem
IF I understand the problem from the limited info in your question, the problem is a distorted picture on whatever surface [probably a wall, or screen] onto which the image is projected.
With all lenses, the axis [centerline of the lens projected] MUST be absolutely PERPENDICULAR [in both the vertical and horizontal planes] to the perfectly plane [flat] surface onto which the image is projected.
IF for example, the projector is mounted in a rear corner of the room, and the camera is aimed downward and to one side to project the image on the center of the opposite wall, or a screen located there, the image will be distorted. It will be larger on one edge [fartherist from the lens] and smaller on the opposite [nearest] edge.
If it is non-perpendicular in only one axis, then two opposite edges will be different lengths, and if out of perpendicular in two axis then no edges will be the same length.
The solution to this problem is that the center axis of the lens must be perpendicular to the surface projected on, in both vertical and horizontal axis.
Feb 14, 2009 | Sharp BQC-XGE630U/1 Projector Lamp for...
Screen seems to have scrape on-how expensive is new screen-only 4
Hi, dealer cost on the screen assy. is $290 plus s&h which is probably about $45, been quite awhile since I ordered one so not sure on s&h. You may be able to seperate the 2 screens and clean it up depending on what caused the mark, be advised you clean these with warm water and a LITTLE dish detergent . NEVER use windex or any other chemical type cleaner. rub gently straight down on front screen and in a circular motion on the inside screen. Before seperating the 2 screens mark both of them with a piece of tape at the top edge so they go back together exactly as you took them apart or the image will be all blurred, hope this helps, video-tek
Feb 05, 2009 | Hitachi 57F500 57" Rear Projection...
Replaced colorwheel and now we have blue images
remove the small black pin jumper in the back center of dvm modual.
it looks like a larger hard drive jumper.
ther is a squair hole cut in the tin bach mesh
use tweesers to remove the black jumper.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Colors off
I have the same problem, would like an answer.
Aug 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Panasonic projection tv,model#pt-47wx49
Did you replace Both STK392-110 Convergence ICs?
May 03, 2008 | Televison & Video
Projection off the screen?
Try pressing the "Aspect/Prog -" button on the remote - it should be just underneath the number 9 key - try pressing once, see if it fits better, try pressing again to see if it improves until you get a better match
Feb 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Television picture gets larger
Your problem most likely is in your high voltage circuit, and the 160 volt radial lead capacitor is probably gone high ESR or changed in capacitence, this usually happens during bright sceens or sceen change.
May 24, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Mitsubishi WS-65819 TV Logo
18 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
