Sanyo DVD Player, coming up Disc Tray Locked
I have a Sanyo Dvd/Surround Sound player and we are having trouble with he disc tray. When you try to open the tray it comes up that the dosc tray is locked.
Unfortunatly we have had this a while and was brought off a friend, and we can't recall if the manual/instructuions were included which also means I am not too sure of the exact model.
Any help is grately appreciated.
Thanks
Jo
  • 13,433 Answers
Basic things to try first
-unplug and try again
-hold down the eject button to eject the disc
look in the front and the back for the model number.
Posted on Jan 06, 2009
    Genius:
  • 1,550 Answers
Try pressing repeatedly the eject button while you turn on the unit. If this doesnot work
then it is a mechanically problem in your player .
You need to manually open to take out the dvd .
The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
Also if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin.
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
Hi, I have a Sanyo DVD-SL20 DVD Player which has fried a couple of components in the power circuit, the problem I have is that the nephew has left his favourite DVD in the machine and with no power getting...
Good day.
You only have to do is remove the top cover of your DVD by unscrewing it.
After that,the internal parts will reveal so you will see the CD tray or the CD mechanism assembly.
Next,when the disc assembly is having a top cover remove it,by loosening all of screw from that cover
And finally you can get the CD from the tray or disc assembly..
Thank you and good luck..
Apr 11, 2011 | Sanyo DVD-SL20 DVD Player
Dvd is stuck
Before you remove the DVD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
  • Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
  • Never work on an electrical device that's still plugged in.
  • Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
  • Follow these steps to remove it
    Step 1 Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Step 2 Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  • Step 3 Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
  • Step 4 Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
  • Step 5 Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
  • Step 6 Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
  • Oct 10, 2009 | iLO DVDR05 DVD Recorder
    No disc error
    Yes bcoz you need to clean the lens with a lens cleaner CD....
    Sep 19, 2009 | Televison & Video
    Trey locked
    There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
    May 24, 2009 | Sony DVP-NS700P DVD Player
    Sanyo DVW 7200 Disc Error
    check to see if the disc spins......As in place the disc in the DVD player with the label in a position that is readable to you....Put the disc in close the tray and wait a few seconds. Open the tray and se if the disc actualy has moved. If it hasent then the motor is bad and not worth replacing!
    Jul 07, 2008 | Sanyo DVW-7200 DVD/VCR
    Dvd tray is locked and i cant find the manual to unlock it.
    Press the open button down for 5 sec and the dvd player will say unlock and then you can hit the open button and the tray will open. I just did this. IT WORKED YEAH!!!!
    Jan 31, 2008 | Sanyo DVD-SL20 DVD Player
    DVD Tray is locked
    Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
    Jan 18, 2008 | Sanyo DWM-390 DVD Player
    Cannot open the disc tray
    I see if thats the problem, the memory IC was been shocked by voltage caused by a capacitor, all I can say is to open your cd/dvd and unplug the memory IC and try to put it back, ussually its a 8 pin IC, I have a problem same as this before from a custumer but its a tv reciever.
    Jan 13, 2008 | Sanyo DVD-7201 DVD Player
    Disc Jammed
    The best way to get your DVD out of the player will be to open up the unit with a screwdriver. Be careful to make sure you find all the screws and make sure if they are different you note which hole they came from.
    If you feel uncomfortable with opening up the unit yourself, take it into a service center.
    Mike
    Oct 30, 2007 | Toshiba SD-3109 Multi-disc DVD Player
    Televison & Video Logo
    37 people viewed this question
    Top Televison & Video Experts
