Question about Saeco Vienna Espresso Machine
It's approx 8yrs old ,gets used every day and works perfectly except there is water leaking from around the steamer itself and when I shut of the steamer it continues to release steam for a minute or so.
  • jand2004
    jand2004 Nov 07, 2012
    It doesn't leak when not in use:)
  • 1,238 Answers
So you possibly have worn out o ring .
Posted on Nov 08, 2012
SOURCE: Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Posted on Nov 07, 2007
mirran
  • 515 Answers
SOURCE: Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Posted on Aug 06, 2008
EsWorld
  • 1618 Answers
SOURCE: frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Posted on Feb 27, 2009
  • 1089 Answers
SOURCE: saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Posted on Jun 09, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Posted on Nov 15, 2009
Water not pumping
Is the pump running? If so I would say you lost your impeller. If not running I would check for a circuit breaker for the motor.
Apr 10, 2013 | Intex Automatic Salt Water System for ...
Hi i have a F&P intutive eco washing machine, approx 8yrs old & it seems to have trouble getting enough water & now after the first spin in shows fault code 136, i also have trouble with marks...
I have not had good experiences with this washer My personal opinion would be to purchase a good second hand washer from craigslist as the repairs on this unit will probably reach 300+ including parts. You can get good second hand washers for that or less.
May 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Every day or 2 I have to mop up water on the freezer side of my side by side. it is about 10 years old now.
sounds like the drain is blocked.you might have to remove the inside back panel in the freezer but look at the bottom of the panel,if you see ice there,there's a drain hole under the ice,melt it out with a hair dryer then you have to clear the drain,i use a steamer to do this,i stick the nozzle into the hole and the steamer blasts through whatever is in the hole,if you don't have a steamer you can try to melt the ice and then blow hot air into the hole to melt the ice down in the drain,then use a turkey baster or anything that will blow into the hole,when you think the drain is clear pour hot water into the hole,if it goes down the hole it's clear if not keep hitting it until the water goes down,watch out trying to snake anything into the hole,the lines are plastic,you can try a plastic tie to snake down the hole.if the drain isn't blocked check to see if one of the water lines are leaking from under the fridge or you could have a problem with the ice maker but you'll see ice forming from that,,good luck.
Apr 12, 2011 | Admiral Refrigerators
Good Afternoon, We have a Kenmore Elite HE4t which works just fine except that when going to do a load the next day there are several inches of water in the bottom. No error codes. Running Drain and...
sounds like the input valve is leaking, not shutting entirely when it's supposed to.  most probably will need to be replaced.  have done numerous times and always solves problem.
Aug 02, 2010 | Washing Machines
We put things(meats,water,veg.) anything but
check the cold deflector door for proper operation, then check the cold control itself as it may be defective
Nov 01, 2009 | Freezers
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
Replacement basket for Black & Decker HS800 Flavor Scenter Rice Steamer
I would not recommend replacing just the plasic basket, too expensive. Once the plastic parts begin to fail, the uint has seen better days (our basket was still ok, but the unit started to leak out the bottom and the timer would stop during the steaming).
Bought a replacment B&D Handy Steamer, oval shape allows longer food items to be steamed (approx 10"x8"), water res & can be filler while steaming. Price was $25 in local hardware (Jan 09). Not worth fixing the old one IMO.
Apr 14, 2008 | Black & Decker HS80 Rice Cooker
Saeco Vienna Espresso Machine Logo
47 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
