Question about SVP PP003 Portable Pocket Projector
I have an svp pocket projector that will charge, but not power on
When I plug in the charger the led is orange and will fully charge overnight and led goes green. Will not power on when charged or charging??
4 Suggested Answers
SOURCE: MY BLACK SVP DC12V WONT TURN ON!
i had the same problem but what happend was that the battery was in the wrong way try checking the batt.
Posted on Aug 19, 2008
  • 26 Answers
SOURCE: I own a SVP XThinn 508 digital camera and can't charge it for use
best buy or Ebey:)
Posted on Oct 25, 2009
  • 4 Answers
SOURCE: could i charge my svp i6pro from computer
Yes with the correct usb cable
Posted on Sep 10, 2012
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
I need to READ the battery charger instructions for a Minolta Dimage G500?
I suggest you charge the battery overnight and in the morning if the LED does not change color then the Red LED on the charger only indicates that there is mains power to the charge adapter.
Jul 11, 2012 | Konica Minolta DiMAGE G500 Digital Camera
I purchased a Pronto 41 wheelchair and a Winsunny battery charger. The charger didn't have a manual so I'm wondering what the best procedure is for recharging the batteries. Do I need to turn the...
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
May 30, 2011 | Electric Mobility Pronto M41 Power Chair...
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
I simply need to know what the 3 colored LEDs on the handle represent. There is a red one, an orange(yellow) one, and a green one. I lost the manual and need to know when the battery is fully charged. ...
Red, Yellow, Green are the battery level indicators, Red being the lowest like a fuel gauge. If the green comes on right away after plugging in the charger then it must not indicate the charge cycle. If its a 3Ah battery whats the charger output amperage? Then you could just do the math to figure out how long it would take to charge that battery to full with the output. Otherwise it shouldn't hurt it to leave it plugged in overnight or at least a few hours to charge it.
May 04, 2017 | Vector 2M Pwr Rch Spotlight
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
Im getting an orange power light when charging allso it wont power on
Usually that indicates a hardware problem. Try removing the battery and leaving it out overnight then with the charger ONLY try turning it back on. If it turns on GREAT. Now try it with the battery back in.
If that doesn't work it's toast :(
Nov 26, 2009 | ASUS MyPal A632 Pocket PC
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Jun 25, 2009 | Samsung L100 Digital Camera
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
SVP PP003 Portable Pocket Projector Logo
48 people viewed this question
Top SVP Office Equipment & Supplies Experts
Vladimir Frolov
Brett Duxbury
Brett Duxbury
Are you a SVP Office Equipment and Supply Expert? Answer questions, earn points and help others
