Question about Lexmark T630 Laser Printer
Lexmark T630 printer
Job can not print because header is not in the printer
All Office
  • 58 Answers
SOURCE: Lexmark error codes
Too many to list here. Try justmanuals.com, you can get the service manual for about $10.
Posted on Jan 22, 2008
HandyManny
  • 4 Answers
SOURCE: printer problem
Hello, it is likely that the transfer roller requires replacing. You may be able to purchase the roller from a local office supply, otherwise buy on line. However, there is more to it...
The error means, the Transfer Roll Cannot start servo operation. Verify correct cable connections from the Engine board to the HVPS (high voltage power supply). Make sure there is continuity between the transfer roller and its contact on the HVPS; replace the transfer roll if the continuity is correct.
If there is no continuity, make sure the HVPS contact returns to its upward limit when depressed, and make sure the left bearing of the transfer roll is making proper contact.
If the wires are all connected correctly, and there is continuity through the roller contacts, replace the roller.
Posted on Feb 23, 2008
Ajkill
  • 2035 Answers
SOURCE: printer locks up
  1. Click Start, Printers and Faxes and double-click on the Lexmark printer driver.
  2. Open the Printer menu and select Cancel All Documents. This will purge the print queue so as to allow the printer to print or uninstall the driver.
  3. If the print jobs are not removed from the queue, click Start, Run, type Net Stop Spooler, and press ENTER.
  4. Click Start, Shutdown, and select Restart. The documents or the print jobs should be removed.
If you are having difficulty deleting the print jobs in the printer spooler, do the following:
  1. Restart the PC in "safe mode". To do this:
    1. Click Start, Shut Down and select Restart.
    2. While the PC is restarting, press the F8 key on the keyboard. Note: Do not hold down the key down, but be aware that you may need to press it several times.
  2. When in safe mode, click Start, My Computer.
  3. Double-click on the (C:) drive.
  4. Double-click on the Windows folder.
  5. Double-click on the System32 folder.
  6. Double-click on the Spool folder.
  7. Double-click on the Printers folder.
  8. Select the contents of this folder and click Delete.
Posted on May 13, 2008
  • 987 Answers
SOURCE: printer won't delete job
First goto Start>run>type services.msc then find print spooler then stop it ...
Goto Start>run>type spool > goto printer and delete all files ...
at last goto Start>run>type services.msc then find print spooler then start it ...
Posted on Aug 30, 2009
webmaster21
  • 803 Answers
SOURCE: how do I print config pages for Lexmark T630,
1 Make sure the printer is on.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Print Menus, and then press Select to
print the page. The message Printing Menus appears on the
display.
4 Verify that the options you installed are correctly listed under
“Installed Features.”
If an option you installed is not listed, turn the printer off, unplug
the power cord, and reinstall the option. See Step 3: “Install
memory and option cards” on page 30 for more information.
5 Verify the amount of memory installed is correctly listed under
“Printer Information.”
6 Verify that the trays are configured for the sizes and types of
print media you loaded.
or
3 Press Menu until you see Print Net Setup, and then press
Select to print the page.
4 Check the first section on the network setup page and confirm
that Status is “Connected.”
If Status is “Not Connected,” your LAN drop may not be active
or your network cable may be malfunctioning. Consult your
network administrator for a solution. Afterward, print another
network setup page to verify connection to your network.
or
1 Launch the CD.
2 Click Quick Reference.
3 Print the documents.
The same Quick Reference pages are stored in the printer. To print
them:
2 Press Menu until you see Help Menu, and then press Select.
3 When you see Quick Reference, press Select.
Posted on Sep 25, 2009
(Lexmark Optra T 630 is printing a blank page at the end of every print job
Hi there, what program(s) are you printing from? This can often be caused by a Word doc having extra carriage returns at the end of the document which carry onto another page. These arent normally visible unless you click on the Show/Hide (or "paragaph") ¶ symbol to display formatting marks.
Tommikat
Dec 07, 2010 | Lexmark T630 Laser Printer
Making a clicking noise when it prints.
Here is a great guide that you can follow to try to identify where the noise is coming from and try to fix it or have it fix.
http://bit.ly/dif9Ck
Feb 06, 2010 | Lexmark T630 Laser Printer
Lexmark T630
If you are using the Postscript driver, switch to one of the PCL drivers. Either PCL or PCLXL.
If you are using PCL, switch to a different driver.
If all of the above fail, send me a Print to File so I can debug it.
(janddgasrepair@verizon.net)
Don
Apr 07, 2009 | Lexmark T630 Laser Printer
Lexmark T630 Hangs with Parallel Busy
try replacing the ethernet cards in these printers these have nvram chips that are known to fail. a failing chip can create stalling. t630 632 634 are the only lexmark lasers that will not boot all the way with out the ethernet card
Nov 17, 2008 | Lexmark T630 Laser Printer
T630 cannot print color
just a wild guess. it may not be capable of printing in color.
check if you indeed have color cartridges installed.
it says B/W - Black and White.
http://www.dooyoo.co.uk/laser-printer/lexmark-t630/
escription: Model ID 0010G0110 / Lexmark T630 - Printer - B/W - laser - Legal, A4, A4 Long - 1200 dpi x 1200 dpi - up to 35.1 ppm - capacity: 350 sheets - parallel, USB
Apr 28, 2008 | Lexmark T642 Laser Printer
Lexmark t630 noise problem
You printer may need a maintenance kit or the redrive replaced.
Jan 03, 2008 | Lexmark T630 Laser Printer
Lexmark printer problem on HP-UX
You should check your drivers to be sure the Lexamrk ones are being used and that the HP ones have been deleted.
Dec 06, 2007 | Lexmark C510 Laser Printer
Lexmark T630 Laser Printer Logo
116 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
