Trane xr12 heat pump switching to aux
I have a Trane XR12 today it got a tad bit chilly not much but i wanted to get the house a bit toasty anyways, I noticed that the air wasn't coming out warm, then it was, i looked at it because i thought it was odd, and it switched to Aux heat. that is the only way the heat will work, it is switching to AUX heat by it's self i live in South Ga so it doesn't get cold enough for the AUX heat, the outside fan works, everythign seems to be working fine but it wont stop switching to AUX heat any suggestions on what might cause this?
  • smackdye
    smackdye Nov 08, 2012
    I dont know how to comment on each one so ill make a group effort "run capacitor for the fan" The fan works, it comes on with no problem......"you have a heat pump which removes heat from outside air when it is too cold out below 30*" it was like 60* outside........"How many square foot are you trying to heat? What is the outside temp? What is the inside temp? What size unit (BTU output) do you have?"..2000 sq ft., outside temp was like 55-60 degrees...inside temp was like 64 degrees I was just wanting to knock the chill out so i could shower...it worked perfectly last year, this year it isnt..no clue on the btu's
  • Heating & Co... Master
  • 1,449 Answers
Sounds like the compressor is not running. Possibly a bad capacitor. Check system in cooling, see if it cools. If it does cool then you likely have a reversing valve issue. Good Luck!!
Posted on Apr 30, 2017
3 Suggested Answers
  • 767 Answers
SOURCE: what does aux mean on a honeywell Thermostat?
The aux switch is for electric heat banks installed in the air handler. Depending on the outside temp. it may not be efficient to run in heat pump mode but in aux. or emergency would run the electric heat in the air handler.
Posted on Dec 11, 2009
  • 1175 Answers
SOURCE: outside fan runs constantly Aux Heat only 50%
Let's start out by your statement that the fan would not run, then you changed the contactor, not it won't stop running.
I believe, based on your info, here's what you need to do. Kill power to the unit. The 2 wires bringing power to the outdoor unit should be on the top 2 terminals. The 2 fan wires should be on the bottom 2 terminals. This is providing that the contactor is mounted Vertical. The could be an outside chance that the unit has a short in it and you are getting voltage feedback somewhere.
Take another look.
Posted on Dec 31, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane XR12 Heat doesnt work after 15minutes of operation
Sounds to me like the outdoor unit is malfunctioning. Could be a control board going crazy, could be the reversing valve leaking. A trouble call to the local contractor is the best idea, preferably a firm that deals with your brand.
Mar 31, 2014 | Heating & Cooling
Ac is set at 74 and it only cools to 80
system needs to be charged check filters and coils make sure they are clean first could be an air restriction issue to your intake
Jul 28, 2012 | Heating & Cooling
Trane xr12, fan works but compressor doesnt come on.
Check the capacitor and contactor. You may have wires burnt at the compressor terminal from corrosion.
Trane xr12 blower stays on after first cool cycle run
Hello, this is usually caused by a sticking fan relay on the intergrated comtrol board. You may be able to tap on it to shut it off but eventually the control board will need to be replaced.
Jun 02, 2012 | Heating & Cooling
My trane xr12 wont run. i checked the capacitor and its good but still nothing is working.
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 02, 2011 | Heating & Cooling
No heat on trane XR12 heat pump
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Dec 25, 2010 | Heating & Cooling
I have a trane XR12 Heat Pump. The cooling fan on the outdoor unit does not run nor does the compressor. The fan motor heats up and hums. I am guessing that the problem is the start capacitor on the fan...
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Jul 29, 2010 | Heating & Cooling
Air Conditioner compressor fan stops, Capacitor wired wrong?
Purple should be on "C".
The fan motor may be destroyed now. Switch the wire and see if it keeps running or not.
Apr 28, 2009 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
