Question about Dacor Preference SGM304 Gas Cooktop
Dacor Gas Cooktop- spiderweb blocking gas flow
The flame is a slow burning, wavering flame. A friend mentioned it was likely to be a spider web blocking the gas flow. I'm a little nervous about sticking something down the tube. Also I don't know how far down it could be.
  • 110 Answers
SOURCE: Dacor cooktop ignition problem
TAKE THE BURNER CAPS OFF AND CLEAN THEM REALLY WELL AND MAKE SURE THAT THEY R PUT BACK ON PROPERLY THRER ARE GENERALLY A NOTCH THAT HAS TO BE LINED UP JUST RIGHT FOR THE CAPS TO FULLY SEED TO PROMOTE PROPER LITING
Posted on May 30, 2008
SOURCE: Propane to Natural Gas Conversion
dacor eg486sch
Posted on Jun 16, 2008
marked
  • 6487 Answers
SOURCE: Dacor Cooktop gas conversion
Check this link for the steps:
http://www.skymarkinternational.com/images/resources/38.pdf
Hope that helps.......
Posted on Jun 28, 2008
  • 10865 Answers
SOURCE: Can't remove Dacor gas cooktop knobs-afraid too pull harder
The Dacor knobs have a history of breaking easily. For that reason I recommend that you clean them in place using cotton swabs, tooth brush, etc. WHatever cleaning agent you use, put it on and let it sit for 5 minutes to loosen up any grime.
They do pull off but they often break and they are pricey to replace.
Please rate my answer.
Posted on Feb 12, 2009
SOURCE: Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Posted on Apr 28, 2009
New cooktop ! long flame yellow tips black deposits on pans
This is probably the result of inefficient burning of gas resulting in sooty deposits being left on the base of saucepans etc. It may be that the gas jets are blocked with spilt material and need cleaning. Try removing the gas hub with the gas jet holes in and sliding a paperclip sized rod into each hole to dislodge any material. Blow in the holes afterwards to force any loose material out. If this fails you may need a gas fitter to adjust the gas mixture regulators.
Nov 03, 2013 | Smeg 23 in. SE64 Gas Cooktop
When I turn on any of the knobs the ignitors start however there is no gas flowing.
Hi,Check for gas to the cooktop...if you have gas up to it...
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 16, 2011 | Dacor Preference SGM304 Gas Cooktop
Igniters won't stop Dacor Preference SGM466 Gas Cooktop. Tried cleaning and want to remove the burners. What is the correct way to do so?
Problem is the insulation on the spark wires is dried and cracked. I bet you can hear the sparking coming from inside the unit, rather than where you see the spark, correct? The excess voltage is grounding inside, rather than thru the flame. I believe you pull the burners off and tap those brass rings with a screwdriver/hammer (or buy the correct tool). Then you can lift the entire top off.
Feb 08, 2011 | Dacor Preference SGM466 Gas Cooktop
Miele gas cooktop flame shuts off after lighting. If I keep the button down longer to allow more gas to flow to the burner it will stay on.
I had similar problem.Solved by Miele tech by placing rice grain sized wad of paper towel inside knob so it sits slightly higher on the valve shaft.
Oct 05, 2009 | Miele 35 in. KM391G Gas Cooktop
DACOR COOKTOP PGM-3651S
The top of the unit must come off. I suggest a qualified Dacor tech.
Mar 15, 2009 | Dacor 36 in.PGM365 Gas Cooktop
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
Gas Stove Top Burners
The burner are fixed only maintenace are to clean burner /clean holes and edge in order flow of gas good performance.At the back if you want make more good performance of your top burner clean the nozzle where the air and gas mix . Clean the nozzle w/fine niddle /sometime if will corrode with rust and dust to struck flow of gas.
Dec 23, 2007 | Dacor Preference SGM466 Gas Cooktop
Oven Striker
If I'm not mistaken, these dacor cooktops have an automatic re-ignition (meaning if the flame goes out, it will just relight it without you having to do it) If none of your burners will light, you probably have a bad spark ignition module. These are somewhat hard to change, as you have to take all the burners off and disconnect the spark wires and take the whole top of the cooktop off to get to the inner workings. Also, to get these burner bases off it takes a special tool by dacor, AND you usually have to replace all the burner seals once you take them apart.Your other, simpler option is to unplug the cooktop and plug a lamp or something in to the outlet the cooktop is using, just to make sure you have power. Just cause the breaker doesn't look like it's tripped, doesn't mean it isn't bad and the outlet is dead. Hope this helps!
Oct 12, 2006 | Dacor Preference SGM466SS Gas Cooktop
Dacor Preference SGM304 Gas Cooktop Logo
24 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Lakeland Appliance...
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
