Wiring a garrison thermostat model THM321 with a Rc and RH wire and only 1 R terminal.
I have 5 wires in the wall (RC, RH,Y,W,G) and only 4 terminals(R,Y,W,G). Manual says to attach RC and RH to corresponding terminals. There are no RC and RH terminals.
4 Suggested Answers
machtcl1
  • 61 Answers
SOURCE: I'm trying to install a
If the system worked before with three wires then the fan wire(green) must already be jumped to the Y terminal at the furnace. You should be able to run the red wire to Rh and Rc, run the white wire to W and run the yellow wire to Y on the new thermostat. You will not have control of the fan (ON or AUTO) from the thermostat. R is 24v from the furnace, W is the Heating circuit and Y is the Cooling circuit.
Posted on Jan 01, 2009
carldc3
  • 82 Answers
SOURCE: Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Posted on Jan 05, 2009
heatman101
  • 43501 Answers
SOURCE: three wire system, going to a five terminal
The Rc and Rh should have a jumper wire between them let it in. and hook the red wire to one of them it does not matter which one as they are jumpered. The white wire goes on the "w" terminal and the Blue wire will go on the "G" green terminal to run your fan.
This should get you up and running again!
Posted on Nov 13, 2009
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
I am wiring a Honeywell wifi unit and I used a separate 24v transformer and connected to the c and rc terminal. My system is ac and heat and uses both and rc and rh wire. I wired the rc to the r ter
A thermostat is a switch. It connects 24vac from one terminal to another depending on the request. The 24vac comes from a transformer, usually located in the furnace and connects to the R terminal. Since you are using RH and RC without a jumper between it means there are two transformers, one in the furnace for heating (RH) and one in the air conditioner condenser used for cooling (RC).
Your old thermostat was probably mechanical and did not have a C (24vac common) terminal. Your new thermostat requires power to operate therefore needs a wire connected to a C terminal. I would get rid of the transformer you added and look for an unused wire in the bunch at the thermostat. If it's there connect it to C on the thermostat and to C on the furnace. Remove any jumper from R to RC or from RH to RC depending on your thermostat and connect wires same as the old thermostat.
Jul 04, 2014 | Heating & Cooling
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
I bought a honerwell regular digital thermostat and changed it trying to follow directions the 4 (four) wires coming out ofn wall and that were connected to old thermo were red, black, yellow and white. ...
Wiring color to Thermostat Depending on what thermostat youhave and existing wires. Typically red and white are for heat and yellow andgreen are for cooling. On base of thermostat there should be initials stampedto identify wires by color. R. W. Y. G. Possible Rc. and Rh if so for most usesyou need to jumper these two together. You may have a blue wire instead ofyellow or green. If so just hook blue to y or g. Hope this helps you. Thanks.
Jan 05, 2011 | Heating & Cooling
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
I just bought a repo house and there is no identification on the wires coming out of the wall for the thermostat. I have a red, green, white, and blue wire coming out of the wall. I need to know where to...
The best way is to see where the wires are connected at the furnace and duplicate them at the thermostat but typically the connections are:
Red wire to "RC and RH"
White wire to "W" (for heating)
Blue wire to "Y" (if you have central air)
Green wire to "G" (this is for the furnace blower)
Aug 27, 2009 | Hunter Fan Company 5/1/1 Programmable...
Jan 05, 2009 | Honeywell Electronic Programmable...
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Wiring a thermostat
your red wire will go to the R, RC, or RH terminal on the stat does'nt matter which one ,this is the wire that provides 24 volt from the furnace. the white wire will connect to the W terminal on the stat. If there is a jumper wire that came on the stat going from RC to RH leave it on.
Mar 08, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
548 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
