Question about Sanyo DP46849 46 in. HDTV
Switched whole power supply from another set and still does the same thing.
  • Sanyo Master
  • 933 Answers
I would suspect a failing LCD panel
Posted on Nov 08, 2012
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
SOURCE: sanyo lcd tv flat
I have researched this problem and it is so common we that own this piece of junk ought to form a class action suit and sue. It is caused by a bad part or bad connections to a part called a backlight inverter. It seems the LCD needs a higher voltage than supplied by the 12vdc power pack so this part re-chops the DC voltage to generate the LCD requirement.
The date of manufacture is on the back of these TVs and all the problems seem to be from those made in 2006 to 2008
Posted on May 05, 2009
SOURCE: My Sanyo DP46848 LCD TV display goes black when turned on.
My mother's was doing the same thing (purchased 2008). Put up with it about 6 months and took it to a repair shop. Bottom line - the display panel has a flaw in and will cost more to replace than the tv cost. See about it now it yours is still under warranty.
Posted on Nov 22, 2010
  • 1623 Answers
SOURCE: i have a sanyo 46" lcd hdtv model #dp46848. its
i would say buy new as it sounds like your whole datata buffer on the rear left has failed
Posted on Mar 19, 2011
  • 3 Answers
SOURCE: Sanyo DP46848 Color lines running from top to
twist the screen. hold opposite corners top and bottom and give a small twist.
Posted on Apr 28, 2011
Hi first i connected the xbox with the given xbox power spply adopter later from that smoke had came out and i immediately switched off so now my xbox power supply adopter was spoiled or not it means i...
The first thing I would do, is find a buddy with another power supply and see if it was not the system. If your system is still under warenty, they will fix it for free. The power supply is way cheaper to purchase than a whole system, so you really need to make sure you're not needlessly buying things.
Apr 14, 2014 | Microsoft Xbox 360 Console
On the back of this power supply, Theres a red switch with the numbers, 115 and 230. depending on which way it was switched on. Can someone please explain to me what this is?
Hi inforis,
That is a setting that will change the voltages, and you do not want to flip that switch. If you do there is a chance you will fry your computer. Different countries use different voltages. It's cheaper to make a switch & some circuits inside the PSU than make a whole new one. List of countries with frequency & voltage (http://www2u.biglobe.ne.jp/~INTECS/WorldVoltage.htm)
Hope that answers you question well enough.
Dec 29, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
I own a Gateway GTW L26M103 LCD Television. When the set is turned off, the power button, which normally glows orange, now glows yellow, at which point the set cannot be reactivated. Unplugging the set...
Tv have power supply board issues,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 03, 2010 | Gateway LCD26TV 26 in. Television
The on/off switch is not working. The only way to turn it on and off is to unplug and plug it back in.
Hello sir/ma'am, hi! here are my likely solution to your problem:
Let start with the easy one: 1. the power supply switch, you may need to feel the switch, like a click or a snap when you press the power button, if this feeling is not present on your switch, this may need replacement. OR
the serious one: 1. You may need a replacement power supply board. the thing is we don't usually replace the bad component, but the whole board, due to modular construction. so if the power supply board is the problem this goes out and put in we then put in a new one.
The defective board goes back to service and testing, if given back to the manufacturer, this takes a lot of process.
Oct 23, 2010 | Philips Magnavox 15MF400T 15 in. LCD...
After 1 -2 hours watching tv hear a pop and set goes off. Cannot switch it back on at power switch but when you pull out the power cable wait 30 seconds and put back in the set comes alive again. Once it...
No,the effect will take longer and longer to turn on tv and dies all together later on.Power supply board have parts call capacitors,have problems.These capacitors parts on the power supply board are dying and have leaking gases.The board where the power a/c cord plug into it.That the power supply board.Searches the power supply board.U now basic eclectronic's,have tools and know basic slodering?These dying capaciitors parts are alway bulges up on it tops or puff up on it tops,must be replaced.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 19, 2010 | Televison & Video
What will happen to the hard drive in power failure?
Power failure as in whole house power failure? Or the computer's power supply failure?
Whole house failure, nothing, the computer will shut off and require rebooting, at which time you may receive a message the computer was not properly shut down, just continue as normal.
Computer power supply failure, same thing, nothing, except the computer will not reboot as the power supply has failed.
Jun 15, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Watching television and lost all power. tv is pluged in and still no red stand by light.
You power supply board is bad. This was most likely caused by a power surge.
I would change the whole power supply to fix the issue but you could also try replace any bubbled capicators for a cheap fix.
The capicators will be less expensive but many times you will have the same issue once again if there is extensive damage to the power supply so the best thing to do is just replace the whole power supply board.
Oct 09, 2009 | LG 50PG30 Plasma HDTV
7945g can't use power supply of 7940
You'll need to buy a another power supply unless you have power over Ethernet. The power supply for 7940G/7960G is CP-PWR-CUBE and for 7941G/7945G you'll need a CP-PWR-CUBE-3. Yes, I know, I just got one of those and it's a pain to configure it, but I got it working... ;-)
P.S. If you haven't notice, you will be dealing with a whole different thing, the configuration/settings will ALL (except for the dialplan file) different from the 7940G... Good Luck ;-)
Aug 02, 2009 | Cisco 7945G IP Phone
Sanyo DP46849 46 in. HDTV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
