Question about Dell Dimension E310 PC Desktop
F1 floopy diskette faliure seek faliure
I have went into F2 when i go there i still cannot get the F1 floppy Diskette Faliure seek Faliure.
    Sergeant:
  • 367 Answers
Ok lets assume you are trying to use the floppy disc if that is the case either the floppy disc is bad or the drive is bad. Replace the affected party. Try a new floppy to test if its the disc.
2 if your getting the error on a computer with no floppy drive installed then go into your bios and disable the floppy drive.
Posted on Jan 05, 2009
    Scholar:
  • 116 Answers
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
"Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a dell c521, and I'm getting a diskette 0 seek faliure ?
Restart the computer and when you see the Dell logo.Tap on the F2 key a couple of times. You would enter the system setup.
1. Use your down arrow key on the keyboard and select the option Drives
2. Hit enter to expand the same
3. using the down arrow key again select diskette drive
4. Tap the right arrow key to switch it off.
Save the same changes by tapping on the ESC key on the top left of the keyboard.
PS. In case you have a floppy drive on the computer check if the drive is empty.
Thanks for using Fixya
Proton
Jun 17, 2010 | Dell Dimension C521 PC Desktop
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
I have a Dim8400 when starting I get 2 beeps then a black screen
Ok to fix that go into your bios when your starting your pc F2, Del are usually the common buttons to get into the bios.
Once in there will be an option somewhere for boot floopy seek, disable it and you won't have that problem anymore :)
Thank you for stopping by Fixya! Feel free to leave positive feedback if this helps.
Feb 08, 2009 | Dell Dimension 8400 PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
F1 floppy diskette faliure
On booting your PC, hold down F12... this will give you a list of devices from which the PC can boot. Make sure you have them in the correct order.... it will tell you how to move them up and down
1. CD-ROM optical drive
2. HDD hard drive
After this it doesn't matter the order.
If this doesn't sort out the problem, you may have to disable FDD (floppy disk boot)
Jan 05, 2009 | Dell Dimension E310 PC Desktop
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Dell Dimension E310 PC Desktop Logo
292 people viewed this question
Alun Cox
