Squeaks sqeaking rotation
    President:
  • 412 Answers
If you can provide more detail on the projector (Brand & Model Name / Number), and more information on the failure, I will try to assist you.
Posted on Nov 22, 2013
Wide, oval tub rotation causing sqeaking
Possibly a worn belt, machine not getting to top speed in order to centralize or possibly a broken balance spring. see my other posts to solve this.
Jun 04, 2013 | Admiral AAV7000A
Squeaking noise right front ?
not sure what type vehicle we're talking about here, although you can lube up the rack and pinion or grease up your upper, if so equipped, and lower ball joints.
Oct 06, 2017 | 2000 Jeep Grand Cherokee
My truck is sqeaking around the belt? I have replaced the tenion pulley and the idler pulley but it is still sqeaking?
if the belt is dry replace it to for it will squeak as well.
also a glaze can be on all pulleys so wire brushing them all will clean the glaze off and eliminate the squeaks too
Jul 31, 2010 | 1992 Ford Ranger
Jeep Cherokee - Sqeaking Undercarriage
If the "sqeak" is more pronoused while going over bumps, then it is most likely a bushing in the front end. Check your fuel tank straps also, they may be loose. Sounds like this are always a pain to locate. Make sure nothing is in the back cargo area. You can also take your foot and shake the exhaust, WHILE THE CAR IS COOLED OFF OF COURSE.
You can also push down on each corner of the vehicle in the front and stand on the rear bumper to try to simulate or isolate the noise. That's all I have for ya. Good luck.
Feb 02, 2010 | 1996 Jeep Cherokee Sport
Sqeaking when kneading oster 2 loaf bread machine - how to oil?
Take out the bread pan and go to a kneading cycle. See if it is squeaking. If yes, then it could be the belt squeaking on the pulley or the motor itself. If it does not squeak when the pan is out, then it's the bread pan paddle and sealed bearing. That sealed bearing is lubed and sealed. It can't be oiled. Hank
Jan 18, 2010 | Oster Kitchen Appliances - Others
Recurring Front end squeak in 97 Acura CL
lol, well...you can either go the route of the previous persons solution or you can- if you are positive the sqeak is coming from the ball joints-spray some WD-40 on it. I wouldnt suggest replacing it again, since you just did it and chances are there is nothing wrong with the integrity of the part, your just getting an annoying byproduct lol. Like when belts sqeak(which p's me off but i just turn my radio up lol).
Jan 10, 2010 | 1997 Acura CL
2005 chevy Impala brakes sqeak loudly
You brakes are no longer any good. Most times, the squeaking and rubbing noises are caused by brake pad wear, but you say the brakes are fine. Otherwise, if by constant rotation speed you mean the squeaking/rubbing noise is present even when the brakes are not applied, you might want to get the wheel bearing inspected.
also check out -------- The most common would be a loose P/S belt. If it is tight but is still the source, it could be a restriction in the P/S system causing high pressure and resistance in the pump.
Mar 07, 2009 | 2005 Chevrolet Impala
Squeaking noise from front end in cold weather
Bad ball joints. check out front end and make sure nothing else is bad. Good lucka nd thanks for using FIX YA
Mar 03, 2009 | 2002 Oldsmobile Intrigue
k24674
jasbo
jasbo
