Question about HP Pavilion dv4000 Notebook
HP DV4000 Series not detecting newly installed CD/DVD RW
I own a HP DV4000 series Laptop that came with a standard CD RW/DVD Rom, HP part # 391649-6C0. I recently purchased a DVD±RW LightScribe, 8X IDE Dual Layer Drive (HP part #396704-001).
This new drive is supposed to be compatible with my laptop. The new drive is ABLE to play DVD's and recognizes CD's but is NOT recognized as a recorder. I tried using several different programs, (Roxio, Nero, Sonic) to burn DVD's or CD's but I get a message from the programs saying "the program could not detect any supported decoders. Please ensure your recorder is properly connected."
I tried reinstalling the DVD/CD drive, checking the plug & play, & updating the drivers but have had no success. I also tried the boot sequance in the BIOS but again no success.
Any help is greatly appreciated.
    Scholar:
  • 35 Answers
Multimedia audio drivers for hp pavilion dv4000
Go here and find your laptop then download the audi drivers for it.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=453246
Sep 12, 2012 | HP Pavilion dv4000 Series Laptop DVD Drive...
I have win 7 on hp dv4, my dvd drive can't read some dvds
Download and install a CODEC package for your PC this is the problem you don't have certain CODECs installed these make anything invisible to the system without them.
Win 7 CODEC HDTV pack with all the latest CODECs go to www.freecodecs.com download from there problem should be solved.
May 12, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
I have a hp pavilion dv2000 laop top I have windows 7 Some how I got a virus on my computer and it deleted my cd/dvd off my computer i cant find it no where not in divice manger how can i get my cd/dvd...
If you had a virus and you want every thing back to normal and CLEAN RE-INSTALL WINDOWS or use the recover CD, just don't forget to backup all your data first...
Apr 09, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
How do i get to download the driver for the dvd r/rw for my hp dv4305US?
Simply go to the HP website support centre and the driver which you seek will be available there.
Jan 16, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
My NEC computer can't detect DVD-RW on disc.How to make it to detect my DVD-RW disc?
make sure that the dvd drive burner is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd drive then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 14, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
How can I find out if my HP Pavilion dv4000 has a DVD burner?
The simple way is to insert an empty disk and try burning the disk with some content. If it burns, that means you have a dvd burner fixed with ur device. Another way which is comparitively complicated is to check the device in the device manager. Right click on My Computer and click on Manage on that. You will get another window opened
In the left navigation pane, you will see device manager. click on that and see your DVD Drive status. If its given as DVD+ RW then you have dvd burner installed in ur system.
Aug 01, 2010 | HP 419320-001 - HP Pavilion dv4000 Series...
HP DV4000 Series not detecting newly installed DVD±RW LightScribe
The type of CD/DVD recorder is suppose to be automatically detected by your Plug N Play portion of your BIOS. Reboot and press the "F" key combination that will bring up the boot process as opposed to the CMOS Settings. See if the correct DVD model shows up as one of your boot electives. You may be able to change it in that window. If not then reboot to BIOS and change it there.
Jan 05, 2009 | HP Pavilion dv4000 Notebook
HP CD-RW DVD RW COMBO
I HAVE AN HP LAPTOPmag-glass_10x10.gif WITH CD-RW AND DVD RW ON IT BUT WHEN I TRY TO BURN EITHER OF THE TWO IT SAYS DRIVE NOT DETECTED. HOW CAN I MAKE SURE IT IS INSTALLED PROPERLY
Apr 01, 2008 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
HP Pavilion dv4000 Notebook Logo
296 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
