Question about Gateway NE56R12u 15.6" Windows 7 Home Premium 64-Bit Notebook
Gateway NE56R12u sound level very low
Sound level on this brand new computer is so low I can hardly hear the system sounds. System Volume has been maximized is control panel to no avail.
SOURCE: sound not available on compac presario v3614AU
http://www.filecrunch.com/file/~h2ee8p
http://img168.imageshack.us/my.php?image=tmp8727ws7.jpg
Full Driver for Compaq Presario V3614AU Notebook PC in Windows XP
Posted on Jan 01, 2008
mdsaeed67
  • 849 Answers
SOURCE: sound problems on my gateway laptop
u might refresh the system by installing new windows also check the speakers for bad sound.
Posted on Nov 03, 2008
SOURCE: My recovery CD (gateway 7330gz PC) are no working
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
Posted on Nov 28, 2008
  • 909 Answers
SOURCE: MX6442 no sound
download divermax (www.drivermax.com) it will find all your drivers and update them for free.
before that, go int system tools, device manager and right click on your audio device, click on properties,open the driver tab and click on update, if that don't work, click on roll back driver to goto an earlier driver.
Posted on Oct 11, 2009
  • 142 Answers
SOURCE: Gateway M-6843 laptop does not recognize hard drive.
The ticking sound is known as the "click of death". After a while the bearings in the hard drive get worn down, and the read head has trouble finding the data you want. In this case the drive puts the read head back to "square one" so it can try to trace its steps back to the wanted data. this makes a click noise. Thus the "click of death". Im sorry to say you need a new hard drive, and that your data is likely inaccessible without drastic measures. One method you can try is putting the hard drive in the freezer for 10 minutes. This will stiffen the bearings and may give you a couple of minutes to grab some data. You will want to have your new drive installed and windows loaded on it so you can readily access the data through a usb to sata/ide cable, which you can get on line fairly cheap. Other options are services like OnTrack, who have a team of engineers who open drives and pull the platters and try to get your data, but you are looking at thousands of dollars just for them to try.
Posted on Dec 31, 2009
Ne56r12u missing operating system
You need to try re-seating hard drive. If that does not work, MS does offer a free image for Win 7. It is form Digital River. Just check which version is lisensed on your MS Product Key Sticker. Download and burn that extact version and use to install,
Dec 27, 2012 | Gateway NE56R12u 15.6" Windows 7 Home...
Our system does not generate any sound. If we jack the volume to 30, we can hear faint sound which verifies that the connections are all valid. is there a setting or something that needs to be altered to...
I have a similar problem where I hear low sound (music or tv) even after maxing the volume. Have you tried doing a test tone for all speakers and see if it 'temporarily' resolves the problem. I bought this system brand new since 2005 and this is the first sound issues I am dealing with. What works for me is when I shut it down and unplug it for a minute or so...it resumes operating normally! If you come across a permanent solution, please share and I will do the same. Tks.
Jan 14, 2011 | Sony DAV-DX250 System
Sound plays but very low volume even if plug to speakers and amplifier and full volume, you hardly hear anything. Hoping for a solution. Regards,
right click on the speaker icon in the system tray on the bottom right side of the screen and then click to open the volume mixer then make the speaker sound level to 100 %.
or go to the control panel from there click on the sound or speaker icon to open it after that go to properties and then make the volume level to 100%.
This should help to fix the problem.
Mar 23, 2010 | Computers & Internet
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
Microphone too quiet
That's probably not going to work.
Mic level is extremely low compared with line level.
Your sound card is expecting a line level input.
It's simply not made to plug a microphone into (you must be using an adapter or two just to make the connection)
Look for a USB Audio Interface with XLR or 1/4" microphone inputs - these interfaces are pretty generic these days and easy to use ... just plug into your computer via USB and then plug the mic into the interface ... which has a volume control on it ...
I use a Tapco Link.USB ... and like it
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Oct 14, 2009 | Sennheiser E845S (3 Pack) Professional...
Sound plays on my system but i dont hear it at all.my windows
Let's start by checking
  1. Your speakers are plugged into the green connector on the computer
  2. Speakers have power, are turned on, and volume is up
  3. Check your "speaker" icon on your tray (lower right hand corner of desktop) - to make sure volume is up and not muted.
Sep 15, 2009 | Dell OptiPlex GX240 PC Desktop
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Aug 03, 2009 | Dell Dimension 3000 PC Desktop
Low volume sound
I was afraid of that. The speaker system is only half in the monitor the other part(Amplifier section) was in your old computer. Here is a possible solution. Buy an external sound /speaker system. The amplifier comes with it and many can be had at a reasonable cost at **** places as  Walmart , target ,etc. Sorry. but the speakers on  your monitor, I believe ,  will not work with you new computer. Sorry.
Mar 09, 2009 | HP Compaq WF1907 Monitor
Gateway NE56R12u 15.6" Windows 7 Home Premium 64-Bit Notebook Logo
142 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
