Question about Toshiba Tecra M2 Notebook
The bios says 'NO DRIVE". In the peripheral it says hard disk not used. I have ahard disk installed, but it dosent find it! Help
  • Toshiba Master
  • 32,281 Answers
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Posted on Nov 08, 2012
4 Suggested Answers
wings_it
  • 141 Answers
SOURCE: hard drive not recognized
format your hard drive completly with this http://www.killdisk.com/downloadfree.htm
you have to create a boot cd with this software.
once formated reinstall your OS.
But if bios does not see this HD it it's also mean that is dead.
Posted on Jan 02, 2009
SOURCE: toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Posted on May 24, 2009
  • 6771 Answers
SOURCE: installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Posted on Apr 23, 2012
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
My laptop it dosent asept windows xp
SATA HARD DRIVE - XP INSTALLATION
Dec 26, 2012 | Toshiba Satellite L45-S7409 Notebook PC
Disk read error
Sep 26, 2012 | eMachines Computers & Internet
HP Garden Dreams Pavilion dv5-2129wm problem.
You killed the hard drive. It needs to be replaced and you'll need a new operating system to go with it.
Sep 02, 2012 | HP Pavilion dv5020us Notebook
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
Formatting new sata drive with xp disc but cd dvd roms are not showing in bios
first your cd dvd drives
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
then you should be able to load xp
hope it helps
May 10, 2012 | Intel D865PERL Motherboard
I can't install win xp pro. on my G41MT-S2P..i always get "a disk error has occured" prompt
This model motherboard does not use IDE/PATA hard drives.
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive. http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Sep 08, 2011 | Gigabyte Giga Byte Technology Ultra...
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
BIOS , "P.O.S.T. is not completing startup
Sorry to read about your problem, I hope this helps you out.
Not really, you have a complete hard disk failure. plain and simple
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Gateway MT6840 Notebook PC
Toshiba Tecra M2 Notebook Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
