My sony str-se591 won,t power up when i connect to power i here the click but my power button doesn,t work
  • kevin thomas Nov 07, 2012
    i had it unplugged for a couple days. the problem occurred when i had it on for a concert i was listening to. 3 hours in the unit just shut off. i figured it got to hot.
    Top Expert:
  • 14,553 Answers
If the unit will still not work consider having a tech look at it.
Posted on Nov 08, 2012
SOURCE: Sony STR-DE310
Our Sony STR-DE310 displays the message "Protected" and will not operate. We have not used it for awhile, but it worked finte the last time.
Posted on Apr 09, 2008
  • 88 Answers
SOURCE: My Sony STR-DG500 wont turn on just clicks once and nothing.
Sounds like faulty psu (pwer suply unit) Amp is going into protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not psu, sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If on, connect speakers and av cables one by one and test each one on its own until amp switches off, Investigate from there were problem is. Make sure speakerwires is not shorting out.
Posted on Aug 29, 2009
  • 4234 Answers
SOURCE: STR-DH700 won't power up unless I unplug-plug it.
This is a logic problem with the internal microprocessor. A quick experiment: Turn the unit on for about 2 minutes and shut it down. Doe sit power uip in this case? If so, I'd suspect that the heat generated during normal operation is creating an internal problem thaty is preventing the micro from recognizing the "off" condition. The power data line is hung and is not being recognizwed by the micro so any attempt to turn the unit on will fail. The unplug/re-plug essentially clears or resets the unit.
If the unit is new, return it for warranty repair. It will be important to describe when the unit fails however. Try to see how long it must remain on for the problem to occur.
Update this with your results if the unit is not under warranty and we'll try to narrow it down.
Thanks,
Dan
Posted on Nov 05, 2009
  • 5 Answers
SOURCE: i have a sony str de445 and it overheated one nite
you might have burned up some internal parts, it is very important that you keep your unit well ventalated so that it has less of a chance at overheating, check for any internal fuses that might have blown.
Posted on Dec 12, 2009
SOURCE: sony str-de845 powers on, relay clicks sound works
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Posted on Jan 22, 2010
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
I would like to get a users manual for a Sony STR-SE591 receiver. Any Suggestions?
Here: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
This should take you to a page that says "download manual" click it, and scroll down the screen to enter the numbers and then a pdf will pop up that you can save... hope that helps
Jul 03, 2012 | Audio Players & Recorders
Str-de685 WHEN I POWERED I HEARD A CLICK BUT EVERYTHING OFF NO LIGHT.I CHECK BOTH FUSES AND ARE OK.
There is a relay on the power supply circuit board that might be faulty or has bad solder connections. If this relay does not work, power is not applied and everything is "dead". I had to re-solder the speaker relays on my STR-DE675 because they had cracked solder joints which made them work intermittently. It's possible that the power relay is what is causing your problems. If it has bad solder joints it might click, but power might not be able to pass trough the joints.
Does it still click when you turn it on or did it only do this once?
Dec 01, 2010 | Sony STR-DE675 Receiver
I have a Sony STR-SE591 Home Theater receiver. As soon as I turn it on, it goes in to "PROTECTOR" mode. Nothing is hooked up to the amp at all, besides the power cable of course. I am no expert at all when...
could have a blown channel or a bad connection, these where often riddled with connection problems,
get a powerfull magnifier and look for connections that aren't solid and redo them. also check the outputs first for shorts if none amp is probibly ok.
Jun 21, 2010 | Audio Players & Recorders
Sony str-de345 this keeps on making a
the clicking is a power suplie overload some output amp is with problems and shutdown after overheat, when you tap is bad connection inside, normaly is related with sound off after 15min. needs to be checked by tech. to ensure perfect operation.
Jan 30, 2010 | Sony STR-DE345 Receiver
Sony str-de845 powers on, relay clicks sound works for a few minutes then relay clicks again and sound stops. display stays on.
Jan 22, 2010 | Sony STR-DE845 Receiver
I have a sony str de445 and it overheated one nite and stoped working. when i click the power button it clicks as if it turn on but no display or sound or anything, could you help please
Jun 27, 2009 | Sony STR-DE445 Receiver
 Grubhead
Grubhead
