Question about Konica Minolta Copier Toner 7033/7040 900gm 950-414
Konica 7040 trouble code 51-4 - Konica Minolta Copier Toner 7033/7040 900gm 950-414
  • Konica Minolta Expert
  • 414 Answers
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Posted on Nov 09, 2012
3 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Konica 7040, use as network printer?
Not sure if you are saying it has a NIC card or you would like to put one in.
If it does not have one, yes it's expensive and most likely they did not make one for that model.
If it has one
depends on the connections.
IP address is for a network, don't know the setting you are in,but, if there is another connection ( Parallel) this is the big connector that is used in the old machines and computers (before USB) and is connected directly to the PC. so it's considered Local printer and only that person can print, would be an alternative.
Unless you have a wireless router, and put the printer into a shared File
Posted on Sep 30, 2008
  • 6 Answers
SOURCE: konica 7040 error code F-34-3
Friend, this code refers to short-circuit the corona separation and transfer, check for accumulation of toner and do a cleanup in the corona.
Posted on Jun 01, 2010
Konica 7033 F-28-2
High Voltage issue have a tech come. Will have to have Old School knowledge you have a legacy Konica Machine.
Jun 12, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 trouble code 35-1
Access the 25 mode (power the machine ON while holding down the 2 and 5 keys).
2. Select [1: Software switch setting].
3. Select software dipswitch #3 using the left up/down arrow.
4. Select bit number one.
5. Set the switch to 0 (OFF).
6. Press PREVIOUS SCREEN to end setting.
7. Power OFF/ON to exit the 25 mode.
Jun 09, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 error code F-34-3
May 21, 2010 | Konica Minolta Office Equipment & Supplies
My printer is showing a code c-38-51 and will not work
Hi, C-3851 is related to the fusing unit. Specifically, the lower roller is at an abnormally low temperature. Unfortunately you cannot reset the code in a normal manner. Konica Minolta, for health and safety reasons, make fuser related codes engineer resetable only.
I'd rather not post the procedure here, so drop me a private email and I will advise on the procedure.
Regards
Tam
Mar 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
Konica 7033 error code F-51-4
my machine incounter problem F 51 - 4 KONICA 7040 ,pls help to solve this problem.I already done checking the drum cart.
Sep 18, 2008 | Office Equipment & Supplies
Konica Minolta Copier Toner 7033/7040 900gm 950-414 Logo
267 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
