Question about ViewSonic PJ458D Multimedia Projector
My viewsonic PJ458D projector lamp LED flashes amber and the lamp will not come on
This happens when unit is powered up
2 Suggested Answers
fathitkf
  • 1871 Answers
SOURCE: I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
Posted on Apr 12, 2010
Power led are flashing, but the lamp don't working
Hi
Please check the lamp & lamp cover .if o.k then suspected item color wheel or , main board or lamp ballst
Sep 02, 2010 | ViewSonic PJ458D DLP Projector Multimedia...
Hello :
Here is how :
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
please rate !
Apr 12, 2010 | ViewSonic PJ458D Multimedia Projector
The projector start to turn on but the lamp led turns into amber blinking and then it shuts off
the lamp has reached the end of it's life. replace it and reset the lamp timer (through the menu).
Sep 02, 2009 | ViewSonic PJ506D DLP Projector
How to reset lamp timer on Pj458D
turn the projector on. open the menu. go to advanced. scroll down to the first option which should be auto source. make sure this option is checked. while on this option press right once, left twice, right 3 times, then left 4 times. another menu will appear. scroll to lamp time and push enter. this will take it back to zero.
Aug 17, 2009 | ViewSonic Office Equipment & Supplies
Lamp won't come on
Hi
Check the cables, try taking out lamp and put it back in. If all fails replace the lamp.
Hope this helps
Nov 15, 2008 | ViewSonic PJ556D DLP Projector
Unit will not power on
Company said it was defective. Sent back for exchange.
May 30, 2008 | ViewSonic PJ501 Multimedia Projector
My Viewsonic PJ458D lamp not coming on
I have the same problem before. I found a replacement fan. A computer chassis fan works perfect. It should be 60mmx60mm - plenty in E-bay for about $5.00. Very easy to open the unit to replace the fan. It has 2 fans in a rubber housing. Check which one need replacement.
May 16, 2008 | ViewSonic PJ458D Multimedia Projector
Will not power on...
Hi there
Simply search on the net for your nearest dealer and contact them
Apr 04, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
Bulb doesn't light
yip, sounds very familiar
steve, does the pj lamp try to fire up.
does it briefly light up then shut off
these are the typ. symptoms of an expired lamp
Feb 26, 2008 | ViewSonic PJ458D DLP Projector Multimedia...
My ViewSonic PJ458D problem
This is known as 'cycling' and is common with mercury-vapor bulbs nearing end-of-life. When the bulb first starts, it glows dimly and grows in brillance. As the light grows, the pressure and temperature of the bulb also grows--increasing power demand. After a short while, the demand exceeds the ballast limit and the bulb extenguishes until the temperature (and pressure) drop again. Then, the cycle starts over. Bottom line: you need a new bulb (or, the correct bulb).
Nov 13, 2007 | ViewSonic PJ458D DLP Projector Multimedia...
ViewSonic PJ458D Multimedia Projector Logo
44 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
