Question about Panasonic CQ-C1101U CD Player
The remote wire is not blue wat color is it
The only blue wire on the back of my stero has another blue wire next to it with a white tracer wich makes me believe that one is positive and the other is negative for a speaker but what color is the remote wire that is supposed to go to the amplifier its a panasonic car stero
  • 3 Answers
It is blue or yellow or its the only odd color
Posted on Jan 05, 2009
20056 Freestar. Where is the fuel rail pressure sensor located?
I looked up info for the 05. It looks like passenger side rear of fuel rail. Four wire connector, wire colors, gray wire with red tracer-- red wire with pink tracer--lt blue wire with white tracer-- brown wire with white tracer. If you find those wire colors at the connector that should be the sensor.
Number 1 is the vacuum connector fuel pressure sensor, it just makes sense that it plugs into the fuel sensor.
Jun 07, 2015 | Ford Freestar Cars & Trucks
Witch wire on the back of the stero is the remote wire on a pioneer deh-p6900 usb
If you are talking amplifier remote turn on, it should be blue/white. Power antenna remote will be blue.
Jul 29, 2011 | Pioneer Car Audio & Video
What color wire is my remote
The blue wire with a white tracer is normal the remote supply for things like amps and antennas. Hope this helps...
Mar 08, 2011 | Pioneer Car Audio & Video
Hi there...i'm having a little problem installing my pioneer avh-p6600dvd unit...couple questions. I can't seem to identify the accessory line for the unit what color is it? Do i still need the brain even...
on the back end of the deck there are a series of wire thats attached to a push-in plug.you will find:
plain yellow-wich goes to permanent live(12-14v)
red -wich allso goes to permanent live(12-14v)
black-wich goes to ground/earth
light green-wich goes to ground/earth
blue and white-wich goes to the ignition wire of your vehicle(remote)
2 x green(rear speakers)
2 x purple(rear speakers)
2 x white(front speakers)
2 x grey(front speakers)
Mar 06, 2011 | Pioneer AVH-P6600DVD Car DVD Player
I cut the plugs from the facturay harness for the radio now i am trying to hook everything back up and do not now what colors from the harness goes to the stero. then what the other colors go to that are...
Here are the stereo wiring colors.
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Jan 16, 2011 | 1997 Nissan Maxima
On the back of my kdc 135 their is 2 wire that are blue. one without a white strip that says antenna cont. and another that is jus solid blue but i dnt quite remember wat it says, which do i hook my rem...
The antenna wire is used for the antenna and trigger wire for an after market amplifier (blue w/white tracer) It sends power out to power the accessories. I'm not quite sure what you mean by "rem cable" but I hope I've offered enough information for you to make a determination.
If so, please rate my assistance and leave a testimonial.
Dec 28, 2010 | Kenwood KDC-135 CD Player
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
I have a 93 Ford Laser hatch back and I need to know the radio wiring color codes for the wires that plug into the back of the radio-cassette. 1)Orange-green tracer 2)Orange-black tracer 3)Grey-green...
OK this is what I did: First I soldered a wire each end of a 1.5v battery. I then bared the other ends of the two wires and tinned them. Then I touched the wires coming from under the dash in pairs until I heard the resultant sound coming from a speaker. This then told me the position of each speaker in the car. From there it was just a matter of noting the color codes for each pair of wires and from which speaker they came. My Gregory's Laser KH manual had wiring codes, but entirely different to my vehicle. Also there is no indication of what color matches what letter code! Cheers. Gerry
Dec 19, 2009 | Philips Car Audio & Video
I just bought a used dual xd6210 stero deck for my car but i dont have the wireing manual for it. i need the wire color code sheet
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
Jun 10, 2009 | Dual XD6210 CD Player
Panasonic CQ-C1101U CD Player Logo
551 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
