Question about Stoves Ovens
Stoves 700 dgo oven keeps on cutting out
Oven keeps on cutting out , seems like its overheating
watugot
  • 290 Answers
SOURCE: Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Posted on Dec 03, 2007
SOURCE: neff model U1461
your convection element has blown by one online and replace it yourself
Posted on Jun 01, 2008
protek480
  • 1723 Answers
SOURCE: Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Posted on Sep 17, 2009
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: I have an old electric Chef Glendale 600 fan
There is a fuse in the back if you remove the rear panel. Check to see if the fuse looks good. If the element is bad, it won't effect the switch, light, or fan. The switch, light, and fan all run off of there own circuit. If that circuits is bad, has a burnt out fusible link, or the electrical circuit board they connect to is bad, then they won't work. You will likely need to trace the wiring from the control panel to the circuit that runs these three things. Use a volmeter to test for power and you can also use an ohmmeter to test for continuity of the circuit itself.
Posted on Oct 07, 2010
Questrion about stove multi function oven
Thermsl temp sensor circut shorted out oven is thinking its cold heats up till secondary overheat sendor kicks in preventing fire
Aug 26, 2014 | Ovens
Thermal cut out
Probably the internal temperature sensor, not a difficult job but if you attempt it yourself kill all power to oven.
Nov 19, 2013 | Belling Ovens
I have a stoves 700 GDO oven and it cuts out when has been on for a short while?
would inspeck useing a flash light ,,,the cal-rods for damage it will look like bubbles or bumps
Dec 15, 2011 | Ovens
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Stoves 720ef fan oven cutting out
You need to check the oven temp with a thermometer against the temp you have selected.
It is possible that it is getting to hot, causing the safety stat to operate to prevent furher overheating..Most makers state that a 10% tolerance is acceptable, that means it is o/k if the temp is 10% lower or higher than the selected temp.
Make sure any vetilation vents are clear.
Plz rate my solution
Thanks.
Dec 18, 2008 | Stoves 720EF Electric Double Oven
Stoves Gas Oven
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
35 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
